Topic: About the bitrates of MP1, MP2, and MP3 (Read 22257 times) previous topic - next topic
Hello. I've found that bitrates of MP1, MP2, and MP3 have some probable disadvantages.
1: These bitrates are kinda weird:
    1.1: In MPEG-1 Layer 1, the bitrates are just multiplies of 32kbps.
    1.2: In MPEG-1 Layer 2, 40kbps isn't supported but 56kbps is supported.
    1.3: In all layers of MPEG-1 and MPEG-2 Layer 1, bitrates lower than 32kbps isn't supported while they can be enough for some sounds (especially for MPEG-2, but they can in MPEG-1 too, for example at the end of a music).
    1.4: 144kbps is supported for all layers of MPEG-2.
    Probably there are more oddities but these are what I could find right now.
2: The bitrates of MPEG-2.5 are just some of the ones of MPEG-2.
3: Discontinuous transmission isn't supported (it could be by allocating just one bitrate value for leaving the frame empty).
4: The bitrates are not dependent on the sampling rate (they could be given as bits-per-sample values instead of kilobits-per-second), and this causes the frames to have weird lengths on 44100Hz, 22050Hz, and 11025Hz sampling rates.
Why are these the case?
Re: About the bitrates of MP1, MP2, and MP3
You do realize that MPx formats were designed in the early 90s?
Some sacrifices had to be made so they could be used on devices from that era.
Why do you think we have newer and improved formats like MPC, Vorbis, AAC and Opus?
gold plated toslink fan
SIGH! Here we go again...
• Listen to the music, not the media it's on
• The older, the 'lossier'
Yes. Your findings are super interesting. Go on.
The conditions of my findings do not decrase complexity, and the last one even increases complexity (so the complexity would be lower if they did the opposite things).
The most important part of my question in different words: Does indicating the bitrate as a kilobits-per-second value instead of bits-per-sample in the stream have advantages?
You are, of course, aware that only one of these things represents bitrate?
TAPE LOADING ERROR
@itisljar Bits-per-sample represents bitrate too, as long as it's together with the sampling rate value.
I mean, why the bitrate table wasn't for example something like this:
   0: 0bps
   1: 0.25bps
   2: 0.5bps
   3: 0.75bps
   4: 1bps
   5: 1.25bps
   6: 1.5bps
   7: 1.75bps
   8: 2bps
   9: 2.5bps
   10: 3bps
   11: 3.5bps
   12: 4bps
   13: 5bps
   14: freeformat
   15: invalid
Bits-per-sample is bit depth. You know, 4 bits, 8 bits, 16 bits, 20 bits, 24 bits, 32 bits. Each sample is represented by certain number of bits.
Are you sure you're not misreading bits-per-second?
TAPE LOADING ERROR
@itisljar No. Of course bits-per-sample does not represent bitrate on it's own, but it does when it's together with the sampling rate value. For example, 3bps at 44100Hz is equal to 132.3kbps.
Some lossy formats allow the user to set either a bitrate value or a bit-per-sample value. For example, Wavpack lossy allows these settings. If I set for example Wavpack to 400 kbps, it will use 400 kbps for a 44100 Hz sample rate (which is a high bitrate for CD material) but also 400 kbps for a 96000 Hz sample rate (which isn't high anymore, considering the file isn’t downsampled to 48000 Hz like most other lossy formats).
Setting the bit-per-sample value enables automatic bitrate adjustment according to the desired output sampling rate.
Wavpack Hybrid -c4hx6
"Bits per sample" has come to mean the number of bits representing each unpacked (pre-encoded) sample, not the average number of bits used at every sample point. Of course you can count the latter too: if you can compress CDDA down to 225 kbit/s, it corresponds to spending 5 bits per average sample, but "bits per sample" has by the development of the language acquired a different meaning.
I generally don't advocate over-moderation, but too much insistence to use phrases for their wrong meaning, will border on a TOS #10 violation.
Example - hypothetical this time, but who knows next thread:
A "bitrate" of "50" does not mean a compression ratio of 50 percent. Of course, in a parallel wor(l)d, someone could have thought up that "bitrate" would be a nice phrase for bits per bit and it could have stuck.
Yes. And wavpack will encode both files with around 400 kbit/s, no matter what the sample rate (or original bit depth) is. Try it, I just did. It doesn't matter if it is too high bitrate for CDDA or too low for Hires, it will always be that.
By using one sample you are using one fixed point in time, and then you can't just change how many bits are assigned to that specific sample, because you will change the sound. Depending on sample rate and bitdepth, each sample of a song will have it's fixed value, no?
TAPE LOADING ERROR
Thanks, but I don't know a word that I can use for the other meaning of "bits-per-sample".
I think it's the opposite: setting the kilobits-per-second value enables automatic bits-per-sample adjustment according to the desired output sampling rate.
Anyway, I want to ask my question with different words (again): Why are the bitrates of 44100Hz same as the ones of 32000Hz and not the ones of 32000Hz multiplied by 1.378125 (44100/32000)?
So, by your calculations, CDDA audio has 32 bits per sample?
Please, use standardized language. It was enough to use "encoder colors", but this goes to another level.
TAPE LOADING ERROR
My equation was for mono, I forgot to mention, sorry.
Try -b4 (as 4 bit per sample) with stereo files: it's around 350 kbps for 44100 kbps, the double for 88200 kbps, etc...
Disadvantages compared to what?
how about bits per bitword ;)
And so, with digital, computer was put into place, and all the IT that came with it.
1.1: This creates big gaps between the low bitrates.
1.2: This does not have a big disadvantage but is weird.
1.3: I explained this.
1.4: This is not from the standard order and looks unnecessary, limiting the available bitrates at the low side.
2: This limits the available bitrates of MPEG-2.5 to 8 while 14 could be used.
3: Discontinuous transmission can reduce the overall bitrate significantly in some situations.
4: This increases the complexity, and this is the one that I wonder the reason the most.
These codecs are not intended for ultra low bitrates!
The target bitrate for MP2 was 256 kbit/s, for MP3 128 kbit/s. Back in these days (the early 1990s) people compared the outcome with the original uncompressed sound and did not want to torture themselves.
@Sunhillow I already said, but apparently I have to say again: Very low bitrates (like 16kbps for example) are completely transparent for some sounds (at high sampling rates too), like pure tones or humming, which can be encountered at for example the the silent parts of a music or a non-music recording.
Yes, I am aware that 4-bit formats exist, like ADPCM. I am arguing against using that for showing bitrate instead standardized kbit/s or mbit/s.
TAPE LOADING ERROR
I agree that bit per sample could be very confusing (with bitrate per second) with audio compression and video compression as well. But bit-per-sample is often used as measurement for still images instead of bitrate.
Example:
https://cloudinary.com/blog/jpeg-xl-and-the-pareto-front
It's also a valid way in audio, as for example David Bryant does without any debate recently:
https://hydrogenaud.io/index.php/topic,125991.0.html
I don't see any reason to argue with Klymins on that point.
I'm not saying that bitrate should be shown as bits-per-sample, I'm asking that does defining the available bitrates in a way that they don't change with the sampling rate have advantages (the opposite can decrase the complexity significantly)?
I don't remember any VBR Layer 1 or Layer 2 encoders. As said earlier, it's old technologies. Layer 3 was specifically standardized for efficiency. Layer 2 and 3 were not the best tools (especially with constant bitrate) for this purpose even if they probably perform well on specific cases. You just wondering why axes or chainsaw are not used to cut a sheet of paper. They do work, but if better tools exist, most people will use cutters or scissors and won't question why Stihl doesn't adapt their tools to cut your magazine.
