Topic: VERY STRANGE FOOBAR BEHAVIOR  (Read 834 times) previous topic - next topic
Hi , i have foobar on a w7 32bit pc , so , the strange and incredible issue is : as w7 start , foobar strart autimatic too , and if i try to close foobar it will  start again and there is no way to close it , That happen with all kind of foobar vers. and i haven't set up the pc for auto start  foobar . I use the player for a long time , and by a long time , and i can't still fix it.
tks
Re: VERY STRANGE FOOBAR BEHAVIOR
I'd recommend verifying with Process Explorer that things aren't autostarting. If you double click foobar2000.exe process in Process Explorer the Image tab will nicely show possible autostart location.
There are apparently faulty sound devices that can trigger foobar2000 when not wanted. Another similar thread here.
