Topic: Burning a self-sequenced mix CD in XLD…can it be done? (Read 4768 times) previous topic - next topic
It’s been years since I had burned a compilation of various tracks to a CD-R, and back then I used Toast Titanium. Now, I’m an XLD user, but as a ripper and occasional burner.
I needed to grab various FLAC files from my library and burn an Audio CD for a project, and could not figure out how to do so. Is there no way to simply grab some FLACs, drag them into proper order, and burn that to an Audio CD using XLD?
Re: Burning a self-sequenced mix CD in XLD…can it be done?
File > Open Folder As a Disc..., then click Burn CD button in the upper right corner.
Thanks. I’m actually familiar with that command.
What I was hoping for was a way to add tracks from various folders without having to create a new folder and copy over those tracks. I supposed I’d also have to renumber the track file names to change the order? Just feels tedious.
So you need a proper authoring package then, even if that means paying for it.
