Topic: JSplitter (splitter + SMP x64 alternative) (Read 7530 times) previous topic - next topic
Re: JSplitter (splitter + SMP x64 alternative)
Reply #75
utils.CheckComponent('foo_uie_jsplitter')
That is redundant if you have SMP and JSplitter installed at the same time and the script is running inside SMP.
This should be foolproof:
if (!window.Parent) {
Object.defineProperty(window, 'Parent', {
enumerable: false,
configurable: false,
writable: false,
value: fb.ComponentPath.includes('foo_uie_jsplitter')
? 'foo_uie_jsplitter'
: 'foo_spider_monkey_panel'
Reply #76
Then JSPlaylist/smooth browser/smooth browser etc are absolutely riddled with bugs and are grossly sub optimal for the changes in fb2k v2.
Would anyone be willing to update the internal code to adapt to the new features of fb2k v2 without changing the original appearance?
Reply #77
JSP3 to SMP/JSsplitter wrapper
https://hydrogenaud.io/index.php/topic,126859.0.html
Is this not okay?
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD620S, SENNHEISER HD 490 Pro Plus, beyerdynamic DT 1990 PRO, HiFiMAN Edition XS, Bowers & Wilkins P7, FiiO FT5, 水月雨 (MOONDROP) 空鳴 - VOID, Nakamichi Elite FIVE ANC, SONY WH1000XM5 (made a Upgrade/Balanced Cable by myself)
Reply #78
As noted, either use the samples provided (they work fine even if they don't have "everything"), use JSP3 directly (nothing stops anyone to use JSplitter and JSP3 at the same time) or use the wrapper at your own responsibility.
Once the wrapper is stable I will contact JSplitter dev to include JSP3 samples + wrapper as additional built-in samples. Maybe we can add Biography and a few other packages by default too.
If someone is interested on further updating the samples, great. For sure, that will not be me. We have Biography package for all last.fm/Allmusic things, Library tree for the browser and my own Playlist manager (on lite mode is a replacement for anything out there). No other sample needs "update". Except a playback toolbar + Art as seen on JSP3 which I may create at a later point.
Reply #79
The following works without any problems:
\profile\user-components\foo_spider_monkey_panel\samples\complete
Check Biography (version1.4.2.mod.1).
I think the following also works:
\profile\user-components-x64\foo_uie_jsplitter\samples\complete
I started with an installed JSplitter, JSP3, and the WilB Biography 1.4.2mod1 script installed and working fine.  Then I replaced the entire "complete" folder with the one in "SMP scripts complete.zip" posted by regor, using the path "\profile\user-components-x64\foo_uie_jsplitter\samples\complete."  On restart, Biography had lost access to all 3 bio texts and the last.fm picture.  Suggestions?  Should I have added the WilB Biography panel AFTER updating an original JSplitter install with the new "complete" folder?  I'd rather not have to go through THAT again.
Reply #80
There is no need to do anything of that. Package problems were due to japanese chars on the path.
Reply #81
@sveakul
Delete the biography cache folder.
\profile\foo_uie_jsplitter\package_data\{BA9557CE-7B4B-4E0E-9373-99F511E81252}\biography-cache
Reply #82
@sveakul
Bingo!  Works now with the updated "complete" folder, no re-loads.  Thanks Air KEN!
Reply #83
This is the default UI skin based on JSplitter, which I learned about from always.beta in a previous thread.
foobox
https://github.com/dream7180/foobox-en
I tried adding some panels, changing to a different panel, etc. That's about as far as I can go for editing at the moment, but I think it's a good reference skin.
Reply #84
By combining Flowin (foo_flowin) and JSplitter (foo_uie_jsplitter) and overlaying JScript Panel 3 (foo_jscript_panel3) Sample Script "Text Display" and "Thumbs", a Track Info + Artist Image Panel can be created.
Turn off Thumbs and display only one image. Now you have an external display Panel where Artist images change one after another.
Register this in "Keyboard Shortcuts".
https://i.imgur.com/7hAUUbg.mp4
