Topic: foo_vis_vumeter (Read 71652 times) previous topic - next topic
foobrik and 37 Guests are viewing this topic.
Re: foo_vis_vumeter 0.9.5.0 Crashes FB 2.1.4.1 X64
Reply #375
reference: Reply #368
Try disabling milkdrop2 and ProjectM.
Also be sure your processor doesn't fall into the range cited by oops' post about full DX12 compatibility--if it does, get the working Intel driver here:  https://www.intel.com/content/www/us/en/support/articles/000057520/graphics.html
Continue to post in the foo_vis_vumeter thread for support.
BTW, the Foobar section has its own Uploads thread: https://hydrogenaud.io/index.php/board,42.0.html
Re: foo_vis_vumeter
Reply #376
Thanks oops.  Yep, "using a single instance of VU Meter in DUI on x64 in light mode" is me also  ;D .  I'm at .91 currently with absolutely no issues;  will be interested to see what this was about before taking the leap.
Reply #377
still crashes after disabling Project M and Milkdrop also when I go back to v9.0 still crashes
Reply #378
I just updated my reply above, check about the processor version and the Intel DX12 driver.
Reply #379
there were no issues at 9.0 the errors came after 9.0 i will check into reinstalling dx12
Re: foo_vis_vumeter
Reply #381
This is a weird one. The settings structure does not get initialized at all! Not even the default values, just zeros all around. In fact, I'm surprised it got through as far as it did. The statement that finally threw the exception was the empty font face for the FPS text. The FPS font defaults to Calibri.
Side note: C++ exceptions throw with the E06D7363h error code when built with MSVC.
From running a working configuration, the initialization should be hit right after this message is printed in the console:
[204ms] foobar2000 v2.24.1 x64 [standard]
Something is weird in the setup or fundamentally broken. I don't know where.
First try to make sure the download is uncorrupted. Compare the hash of your download with the source I used to upload (e.g., in PowerShell):
(Get-FileHash -Path .\Downloads\foo_vis_vumeter-0.9.5.fb2k-component -Algorithm SHA256).Hash -eq 'bcf9cb6cd17c622e55d2c72eb43249b369ad8eb91868378061eda95bae13fb57'
Then try reinstalling the component.
Another option is to do a portable install and then just run with the VU Meter component (besides the default components). I tested this just now and it works as expected.
Lastly, if you feel brave (and I have no idea if this would even work), the GUID for this component is 0A8B8B7A-2E90-43BB-B395-EB41A124F7E2. You can go into the configuration store and clear the "ui.elem.GUID.*" and the "vumeter.*" entries.
For now this is what I could come up with. Sorry.
Reply #384
downloaded file
Re: foo_vis_vumeter
Reply #385
I'm going to try later.
Uninstall Foobar completely then reinstall with just vumeter without any other plugins. see how this goes. or do without vumeter it was nice while it worked but not absolutely necessary.
Reply #386
Try what oops suggests here:  https://hydrogenaud.io/index.php/topic,126733.msg1058134.html#msg1058134
Are you running the update from the auto-updater or doing an install from downloaded file?
I am going to attempt to remove  foo_vis_vumeter 0.9.5.0 from my system completely as it was updated over top of a previous release. 9.2 Then I will attempt to install it from scratch. Could some kind person tell me what keys in the registry that I need to find to remove it better still a .reg file to run to remove it.
Reply #387
Read the other thread a couple of posts ago by oops. And stay in that thread please.
Moderator: Merged topics
Reply #388
I did a reset on configuration and than re-installed foo_vis_vumeter 0.9.5.0 all is normal again just have to re-install my plugins that I need thanks for all your help.
Reply #389
Here is a update: foo_vis_vumeter 0.9.5.0  works great until I introduce SACD and DVDAudio plugins when it crashes. Have to do a reset to recreate crash reports and dumps
Reply #390
These crash reports are with only SACD plugin installed. I can't do any more on this for a few hours. Just want to keep u updated
Re: foo_vis_vumeter
Reply #391
DVDA does not seem to be installed.
What happens when you install foo_input_sacd 1.5.17?
Re: foo_vis_vumeter
Reply #392
@marktherob2005
Do you use BitDefender? If so, remove it.
Also, since the Audio Device does not support DSD, please delete foo_input_sacd.
Since foo_out_asio+dsd is not installed, Native playback is not possible. There is no point.
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD620S, SENNHEISER HD 490 Pro Plus, beyerdynamic DT 1990 PRO, HiFiMAN Edition XS, Bowers & Wilkins P7, FiiO FT5, 水月雨 (MOONDROP) 空鳴 - VOID, Nakamichi Elite FIVE ANC, SONY WH1000XM5 (made a Upgrade/Balanced Cable by myself)
Re: foo_vis_vumeter
Reply #393
Eh?
My audio device does not support DSD. Foo_input_sacd is perfectly capable to output PCM from DSD source.
Re: foo_vis_vumeter
Reply #394
Yes, of course I know. It's in the settings.
What is it?
This is a separate issue so let's leave it at that.
Re: foo_vis_vumeter
Reply #395
@ Defender my foobar crashed after a couple of reinstall i remember you sent me your vu folder and all is back to normal so thank you
Re: foo_vis_vumeter
Reply #396
What is it?
What are you on?
He has a stable running VU  0.9.5.0 on a fresh foobar. The moment he installs a slightly older foo_input_sacd it starts crashing.
And your advice is this:
What kind of help is that?
Re: foo_vis_vumeter
Reply #397
when I reinstall the vu   meter folder was empty so I used you're
Re: foo_vis_vumeter
Reply #398
@Defender
Don't use anything unnecessary.
Also, FxSound Audio Enhancer seems suspicious.
If you are using FxSound Audio Enhancer and are having trouble, you will often see the answer "Delete FxSound Audio Enhancer".
Re: foo_vis_vumeter
Reply #399
@AIR KEN
This was all working fine before 9.5 came along. I pay and need Bitfefender and also need SACD so you tell me to delete them. Sorry I can't I use them all the time.
This was working with all this software before I updated to 9.5 how will it help to delete all this software. If that's the case I will forgo using VUMETER
