Topic: Duplicate EAC Settings Profile to New CD Drive (Read 1178 times) previous topic - next topic
I have 2 external CD drives hookup to my pc and want to duplicate my existing EAC FLAC settings to the new drive.
Right now If I load my existing EAC FLAC settings profile it changes my drive to my original CD drive; is it possible to apply all the settings to my new CD drive or do I need to go into each settings menu and create a new one?
Re: Duplicate EAC Settings Profile to New CD Drive
The Compression Options dialog (External Compression) isn't drive specific. Your FLAC settings will work for both.
If you want to use the other drive (assuming both drives are connected and Drive Options were set for each), just switch to the other drive.
X
If you haven't setup the Drive Options for the 2nd drive yet, switch to the 2nd drive as above and then press F10 to manually set these.
korth
For AccurateRip you need to insert a key disc into the drive. With a key disc in the drive, the AccurateRip plugin will offer to configure the offset. You may need to try multiple CDs. You need to be connected to Internet.
korth
That worked, thanks!
One more note, I noticed when I rip a cd the cover image is being saved without any extension..I have to add the .jpg otherwise its not associated with any file format. This happens if I have to add the image myself (I confirmed its saved as a jpg when I drag to the cd cover portion of EAC)
I was not able to duplicate this. When I drag somecover.jpg into the CD cover section, I get %albumartist% - %albumtitle%.jpg with the rip as expected.
korth
