Topic: Nero 8 crashes when I load a cue sheet from EAC (Read 3894 times) previous topic - next topic - Topic derived from EAC - Error in CUE sheet
My English is not good but I have a problem with the cue sheet in Nero 8. Nero 8 crashes when I load a cue sheet from EAC and also form fre:ac. The cue sheet is okay, not edited. I can burn a CD with the same cue sheet in EAC 1.8 itself. The audeo file in one wave file.
Re: Nero 8 crashes when I load a cue sheet from EAC
Now that's a blast from the past. Version 8 is 14 years old, probably it mishandles cuesheets somehow. Funny that it crashes instead of just failing.
If you can burn things with EAC, what do you need Nero for? NRG format is also a blast from the past.
I haven't even touched Nero in years since I discovered ImgBurn could do exactly what I needed to do and the versions of Nero being bundled with newer drives just being crapper with each new drive I got.
NRG still allows us to make a disc image of an audio CD and can be mounted by most, if not all, disc emulator programs ;)
Thanks all. If Nero would accept the cue file, I could also burn FLAC files to a CD, same quality, smaller files. EAC can only burn WAV files.
I would like to make a 1:1 copy of the CD, with the right setting of pre-gabs: when there are real pauzes between the tracks, e.g. when track 2 begins after track 1, the counter of de CD player is counting backwards first:  e.g.-3, -2. -1, 0
Only Nero and EAC can do that.
ImgBurn which I mentioned supports cuesheets and their pre-gaps.  Being able to write such CDs with pre-gaps is not exclusive to Nero or EAC.  In fact Imgburn is actually better at handling CD text than EAC is.
@Chibisteve, thank yiou! I will try it!.
@Chibisteven, ImgBurn works fine! It accepts the cue file of EAC 1.8 and the pre-gabs are correct. Thanks very much!
