Topic: Create 432hz AAC Mp3 Flac WAV Foobar component (Read 1794 times) previous topic - next topic
Could somebody Create a Automatic playing Foobar2000 432hz or customizable Hz component that can be converted to AAC MP3 with Standard + customizable Bitrate & WAV or Flac lossless
or make program that can do this why has this not been done yet?
Re: Create 432hz AAC Mp3 Flac WAV Foobar component
File->Add location, then type
tone://432,10
Ok
This will add to playlist 432 Hz tone 10 second log. You can convert it to any format supported by fb2k converter.
If you're trying to "retune" A=440 playback to A=432, you should be able to do so with this component:
https://www.foobar2000.org/components/view/foo_dsp_effect
Yes try the Pitch DSP in the above component (image below).  Also lots of free VST plugins are out there like https://kilohearts.com/products/pitch_shifter .
Lack of need, perhaps?
