Topic: Bitrate Calculator (Read 5498 times) previous topic - next topic
Bitrate Calculator
Some time ago I remember using a little programme which calculated bitrate....it was great for fitting mp3's on to my portable.
I cannot find it, Iv'e searched the Forum and tried Google to no avail.
Can anyone help?
auldyin
Bitrate Calculator
bitrate?
Aren't you looking for a program more like dupeless?
Bitrate Calculator
Thanks for response.
What I was looking for was a little programme which allowed you to calculate the bitrate which would fit eg:
40 minutes of music into 64MB of memory
auldyin
Bitrate Calculator
The equation for that calculation is fairly simple, would you really want a special program for it?    OK, take it easy.
(1) The equation:
bitrate[kbps] = space[kbits] / time[seconds]
(2) unit conversions:
time[seconds] = time[minutes] * 60
space[bits] = space[bytes] * 8
space[K] = space[M] * 1024
(3)The equation for other units - (1) and (2) combined:
bitrate[kbps] = 8*1024/60 * space[MB] / time[minutes] = 136.53 * space[MB] / time[minutes]
bitrate[kbps] = 8*1024 * space[MB] / time[seconds] = 8192 * space[MB] / time[seconds]
That's the nice theory, but I'm not sure about two practical details:
-is the Kilo/Mega conversion correct for MP3 bitrates? or is the factor 1000 instead of 1024? does anybody else know that?
-there may be some overhead related to the actual storing of the files, so you might want to do your calculations with some "headroom". for instance, add a minute or two to the real time. this gives you a slightly lower bitrate (smaller files). just test it for yourself to see how much the "ideal" factor has to be adjusted.
Have fun!
Bitrate Calculator
HDD space:
1 MB = 1024 KB
1 KB = 1024 Bytes
Bitrate:
1 kbps = 1000 bits/sec.
bitrate[kbps] = 8*1024*1024/(60*1000) * space[MB] / time[minutes] = 139.8 * space[MB] / time[minutes]
bitrate[kbps] = 8*1024*1024/1000 * space[MB] / time[seconds] = 8388 * space[MB] / time[seconds]
Bitrate Calculator
Thanks guys....................doddle!!!!
auldyin
Bitrate Calculator
This is what you need.
At the bottom of the page. Audioactive Calculator. Freeware.
Bitrate Calculator
Ph34r my gh3y HTML skillz.
Just hit the http:// code button dude.  Then you \/\/][|_|_  B3  4|3|_3  70  |>0$7 |_][|\|]{$  |_][]{3  4  1337  |-|4><0R.
SEE!!
Translation:  . . . will be able to post links like an elite hacker.
Bitrate Calculator
HDD space:
1 MB = 1024 KB
1 KB = 1024 Bytes
Bitrate:
If anyone is still interested, here is a simple batch script using those methods for video bitrate calculation. Simply copy the code below into "Video_BITRATE_Calc.bat" and run whenever desired.
In this script I am forcing the results to be displayed as even integers. If you would prefer to allow odd integers when they are produced, simply delete these lines:
  • SET /A _output/=2
  • SET /A _output*=2
  • SET /A _video/=2
  • SET /A _video*=2
    - M.
@echo off
color 02
title Video BITRATE Calc...
cls
echo.
echo -----------------------------------------------
echo              Video BITRATE Calc...
echo.
echo PLEASE NOTE:
echo   1) Time = MINUTES (every six sec = 0.1 min)
echo   2) Bitrate = CBR (Constant bitrate in kbps)
echo   3) Size = MiB (file size as shown on drive)
echo   4) Output is adjusted to show EVEN integers
echo.
echo.
set /P  _time=.   Play Length:
set /P _audio=. Audio Bitrate:
set /P  _size=.  Desired Size:
SET /A _output=(( 8388 * _size ) / ( _time * 60 ))
SET /A _output/=2
SET /A _output*=2
SET /A _video=( _output - _audio )
SET /A _video/=2
SET /A _video*=2
echo.
echo.
echo OVERALL Bitrate: %_output%
echo   VIDEO Bitrate: %_video%
echo.
title ... finished!
pause
