Experiencing Noise In Audio Output When Starting VMWare Virtual Machine
2024-06-30 23:24:38
This was not always happening, but it has started happening recently. Windows 11 Professional had a recent update that very well could have introduced this. I am experiencing it under both WASAPI exclusive and ASIO. While fb2k is playing audio to my DAC, I hear audible noise when starting a virtual machine under VMWare Workstation. This is VMWare Workstation version 17.5.2 build-23775571. My VMWare guest VM is Windows 11 Professional with the latest update that matches my host OS. I have absolutely removed USB from the virtual machine setup thinking it may be a USB conflict of some type, but this has not helped. I still hear noise when starting the virtual machine or shutting it down. I have tons of memory with tons free: 192GB with only 11% used with fb2k playing media. With VMWare virtual machine running, this changes to 24% memory used with 46/192GB. I still have tons of free memory available even with fb2k running with my super large buffer configuration. This is a workstation class computer with an i9 14900K Intel CPU. Other than starting and stopping the virtual machine, playback works perfectly in all other regards. I have 64-bit fb2k installed version 2.1.5. I have the latest of all components installed as shown below. Any ideas for this recent problem? I blame Microsoft's Windows 11 update. As I stated, this was not happening until recently.Core (2024-05-02 12:08:22 UTC) foobar2000 core 2.1.5 foo_beefweb (2023-09-03 12:10:02 UTC) Beefweb Remote Control 0.8 foo_chronflow_mod (2022-09-04 20:08:44 UTC) Coverflow_mod 0.5.2.mod.6 foo_converter (2024-05-02 12:08:54 UTC) Converter 2.1.5 foo_dsd_processor (2023-06-09 14:26:38 UTC) DSD Processor 1.2.1 foo_dsp_effect (2024-05-03 06:52:38 UTC) Effect DSP 0.51 foo_dsp_eq (2024-05-02 12:08:58 UTC) Equalizer 1.2.3 foo_dsp_std (2024-05-02 12:09:02 UTC) Standard DSP Array 2.1.5 foo_dsp_vst3 (2024-04-09 17:38:38 UTC) VST 2.x/3.x Adapter 0.12 foo_enhanced_spectrum_analyzer (2023-05-06 15:54:08 UTC) Enhanced Spectrum analyzer 1.9.2.0 foo_external_tags (2023-03-16 11:06:40 UTC) External Tags 1.5.14 foo_fileops (2024-05-02 12:09:06 UTC) File Operations 2.1.5 foo_freedb2 (2024-05-02 12:09:10 UTC) Online Tagger 0.10 foo_input_sacd (2023-02-07 09:15:00 UTC) Super Audio CD Decoder 1.5.4 foo_input_std (2024-05-02 12:08:50 UTC) CD Audio Decoder 2.1.5 FFmpeg Decoders 6.0 FLAC Decoder 1.4.3 Monkey's Audio Decoder 10.30 Opus Decoder 1.4 Standard Input Array 2.1.5 foo_jscript_panel3 (2023-07-04 23:05:04 UTC) JScript Panel 3 3.3.0 foo_metronome (2022-10-22 13:06:24 UTC) Metronome 1.2 foo_midi (2023-05-01 14:02:06 UTC) MIDI Player 2.8.1.0 foo_monkeymote (2024-01-03 01:23:36 UTC) MonkeyMote 4 Foobar 3.4.0.6 foo_musicbrainz64 (2023-04-03 23:29:06 UTC) MusicBrainz64 1.2.9 foo_out_asio (2024-05-31 14:03:56 UTC) ASIO Output 2.2.3 foo_playcount (2023-03-14 11:04:18 UTC) Playback Statistics 3.1.5 foo_playlist_attributes (2024-04-06 15:59:10 UTC) Playlist Attributes 1.0.5 foo_popup_panels (2023-05-21 18:29:28 UTC) Popup Panels 1.0.2 foo_qsearch (2023-05-14 02:02:48 UTC) QSearch 1.0.6 foo_queue_viewer (2023-04-27 19:43:14 UTC) Queue Viewer 1.0.22 foo_run (2022-09-19 08:14:04 UTC) Run services 0.4.5 foo_run_main (2022-11-13 17:16:56 UTC) Run Main 1.0.2 foo_scrobble (2022-09-06 04:43:00 UTC) Scrobble 1.6.0.22456 foo_skip (2024-05-07 16:27:24 UTC) Skip Track 1.40 foo_ui_columns (2023-09-27 02:19:32 UTC) Columns UI 2.1.0 foo_ui_std (2024-05-02 12:08:34 UTC) Album List 2.1.5 Decoding Speed Test 2.1.5 Default User Interface 2.1.5 File Integrity Verifier 2.1.5 foo_uie_albumlist (2023-11-09 23:53:02 UTC) Album list panel 2.0.2 foo_uie_eslyric (2023-04-18 19:25:32 UTC) ESLyric 0.5.3.1031 (Beta) foo_unpack (2024-05-02 12:09:18 UTC) ZIP/GZIP/RAR/7-Zip Reader 2.1.5 foo_youtube (2024-06-26 19:41:45 UTC) Youtube Source 3.9.1
