Topic: CBR AAC Encoder (Read 10925 times) previous topic - next topic
CBR AAC Encoder
Hello. Which encoder can encode LC AAC at a wide range of bitrates and sample rates at CBR with high quality and FhG-MP3 like sound color? (I was tried FAAC and could not encode CBR.)
Re: CBR AAC Encoder
OK, this thing with sound colors has to stop.
TAPE LOADING ERROR
Re: CBR AAC Encoder
Okay, so, can anyone give me an advice for a CBR AAC encoder that supports a wide range of bitrates and sample rates?
Re: CBR AAC Encoder
 fdkaac, qaac , neroaac
Re: CBR AAC Encoder
@shadowking I could not run qaac properly, is there a way to limit the frame sizes in fdkaac? (It should not use larger frames than the specified limit.)
Re: CBR AAC Encoder
fdkaac.exe  --help will tell you what you can do with the application.
What are you trying to achieve, why would you want to limit frame sizes?
TAPE LOADING ERROR
Re: CBR AAC Encoder
@itisljar You will not like it, but I'm trying to get the "sound color" of FhG MP3. I feel like AAC's longer frames make the sound too "loose".
Re: CBR AAC Encoder
Have you tried to ABX anything against original lossless file?
Do you want high quality/transparency or sound that is different from original to get "sound color"?
Re: CBR AAC Encoder
@synclagz Yes, I did some ABX's in the past, but they are not useful in this case as I'm not targeting transparency.
Re: CBR AAC Encoder
Seems like [some kind of vst fx chain] may also serve you well.
"at CBR with high quality and FhG-MP3 like sound color" - your target audience, for that kind of question, that kind of encoder, specifically at HA, is the empty set. You do not see this? Really?
Re: CBR AAC Encoder
Indeed, you should stop searching "the bad quality encoder that is more to my liking".
Either process the original with sound effects that try to generate the sound you look for ( back on your low bitrate MP3 files, it was a kind of aliasing or exciter, similar to what SBR does but generated without prior information), and encode with a good encoder.
Re: CBR AAC Encoder
No, ABX original files and these aac with "loose" sound, whatever that may be.
TAPE LOADING ERROR
Re: CBR AAC Encoder
Filesize is also important for me. And, I want a good quality encoder, why you assumed I want a bad quality encoder?
Re: CBR AAC Encoder
@itisljar I did it, and got 16/16. Here's the files: https://drive.google.com/drive/folders/16cTRYkU__VDOXD76a-UxRcRkLfHozZrr?usp=drive_link . Attr: Sound by nosoapradio.us .
Re: CBR AAC Encoder
You can also put it like this: among the worst codec settings, you are looking for one that is slightly less bad.
Re: CBR AAC Encoder
11025 Hz sample rate? You are losing audible parts by doing this. You don't want to hear all instruments/sounds?
Re: CBR AAC Encoder
Sampling rate and quality are seperate things.
Re: CBR AAC Encoder
This low sample rate (11025 Hz) is affecting quality because you simply can't get all audible sounds that are stored in original lossless file.
Re: CBR AAC Encoder
In my opinion, sampling rate does not directly affect quality. But, if you're using the same bitrate, higher sampling rate means lower quality. You have a different opinion and that's not a problem for me. Also, 11025Hz is a medium sampling rate for me.
Re: CBR AAC Encoder
In my opinion, you are an atom slightly outside the Schwarzschild radius of a supermassive black hole at the edge of the observable universe.
You are of course entitled to a different opinion, but they are all opinions and thus none are more wrong than the other.
A more relevant opinion is that TOS#8 has been inadequatly worded from the dawn of HA time.
