Topic: LAME fastest encoding(-q 9) gives better quality than the slowest encoding(-q 0) (Read 32061 times) previous topic - next topic
Re: LAME fastest encoding(-q 9) gives better quality than the slowest encoding(-q 0)
Reply #50
So, The patched -q3 with noise amp=0 should be same as -q4 (also noise amp=0) in normal versions if i m correct ?
Yeah, I think so. -q3 sets noise_shaping_stop to 1, -q4 sets noise_shaping_stop to 0 - however, that config variable appears to be unused and the other settings are identical.
Reply #52
@maikmerten I prefer patched versions, but I think there is no difference between patched q0 and q9.
Reply #53
Did anybody have a listen to the samples I posted at https://hydrogenaud.io/index.php/topic,126120.msg1047065.html#msg1047065 ? It would be useful to know if ABR has the same problem or if I'm imagining things.
I will soon check these.  In my experience abr has similar problem.
Reply #54
MP3 is just so patched, that it:
First: is not MP3 anymore
Second: do not works uniformely and simply anymore
Reply #55
What on earth are you talking about?
Reply #56
@Klymins Thanks for testing. q0 and q9 should still make a (tiny) difference (they're not the same settings, e.g., for searching the best Huffman codes), but these may not be very evident.
@shadowking Looking forward to your findings!
@a.ok.in I cannot follow, can you elaborate?
Reply #57
By the way, I prefer a FhG MP3Enc encoded CBR 32kbps MP3 over both of these ABR 32kbps examples.
Reply #58
Okay, The winners for me are patched versions.
Reply #59
@shadowking Thanks for your feedback!
@Klymins  I guess FhG MP3Enc chooses other sample rate and lowpass settings. Can you provide information on what FhG chooses?
Reply #60
@maikmerten
ABR mode is definitely better on patched version. No need to ABX. It is obvious. :)
Reply #61
@maikmerten I prefer 22050Hz. FhG-encoded CBR 32kbps MP3 is lowpassed by roughly 8kHz in this speed. I always use the lowest quality.
Reply #62
@Klimins It appears you like lowpassed audio.
With 32 kbps mono, FhG appears to choose 22050 Hz sampling rate with a lowpass of ~7800 Hz.
With 32 kbps stereo, FhG appears to choose 16000 Hz sampling rate with a lowpass of ~4900 Hz.
Transferring these settings to LAME, overall results are somewhat comparable, as far as I can tell.
OP's techno/rave sample:
lame --resample 16000 --lowpass 4900 -q0 -b 32 rave16.wav rave-lame-patch.mp3
The Moby Dick TTS sample:
lame --resample 22500 --lowpass 7800 -q0 -b 32 google-mobydick-male.wav moby-lame-patched.mp3
(LAME encodes with the trivial patch applied)
They still sound *different* IMO, but I guess preferring one over the other is now a matter of personal preference.
Reply #63
@maikmerten Looks like you was not used the lowest quality setting on FhG. Try it, it's cutoff point is a little bit higher at almost 8kHz. Also, I prefer 11025Hz for 32kbps stereo MP3. As my MP3Enc does not encode above 30 seconds and Adobe Flash CS6 does not encode 32kbps stereo, I have to use Fastencc for 32kbps stereo, and it works very well at this sample rate at this bitrate at stereo.
Reply #64
Great... now fastenc... the encoder famous for its pirated copy for Windows ACM codec that had several annoying sound bugs.
Reply #65
I didn't experience any sound bugs.
Reply #66
Browsing through LAME's version history, I determined that the quality regressions (q0 sounding worse than, e.g., q4) were introduced with this change:
https://sourceforge.net/p/lame/svn/6147/
Reply #67
There are certain times where the 'Extreme' preset (-V 0 -q 0 --vbr new) gave me artifacts with tracks that have cymbal decays or certain TR-808 sounds. The issues are usually solved by using -f -V 0 --vbr new instead
LAME: -f -V 0 -Y
 Xing: -V150 -X2 -U2 -HF-1 -TX0
Reply #68
Although I claim no great wisdom in this matter, my LAME encoder of choice has long been halb27s tuned lame-3.99.5o-Fast-CRC, which you will find at RareWares.
Reply #69
finally after 15 years or so people are talking about this, this has been a critical bug for donkeys years
q4 has sounded better since LAME 3.97 (for 320kbps anyway)
even tested this on a function 1 sound system and quality difference was night and day
Reply #70
Not sure who discovered this but thank you
During the pandemic I converted thousands of Archived WAV files to 320 kbps mp3 using the standard LAME 3.99 and always wondered why they sounded bad  and flat
Redone of bunch of them last night and changed -q3 to -q4 and blimey what a difference they sound so much better more weight and much cleaner
Definitely will be re encoding my whole collection with this setting
Reply #71
320 kbps mp3 … always wondered why they sounded bad  and flat
Do you mean, there was audible difference between original and encoded?
hearing a difference vs 320k mp3 is extremely unusual, any chance that was just placebo?
Reply #73
Definitely not a placebo turning the noise shaping off makes a major difference imo
Reply #74
Lame has issues. Recently i have encoded using Fre:ac (lame version 3.100) and it put a clearly audible "pop" sound in one of the songs, which wasn't even there in the first place. I tried disabling the ATH and temporal masking (psychoacoustic model) and the pop was gone. However, it was still "visible" in Spek. That pop wasn't audible or visible in the original flac and i have encoded the same song with other codecs (opus, aac etc.) and none of them produced that.
