Topic: VS2022 compatibility (Read 9072 times) previous topic - next topic
Recently, I updated VS2022 Community Edition to version 17.10.1 and found that component compiled with /MD using the msvcp140.dll included in the foobar2000 installation crash in some cases. However, there are no issues when using the system-installed msvcp140.dll. My current solution is to set the MSVC toolset version to 14.36.32532 (the current default is 14.40.33807, and other versions have not been tested).
I would like to ask if there are any better solutions(except using /MT compilation) to handle this problem so that future updates or project configurations do not need to focus on the toolset version?
test code(/MD and using bundled msvcp140.dll):
#include <mutex>
int main()
    std::mutex mutex;
    // Access violation
    mutex.lock();
    return 0;
Re: VS2022 compatibility
The breaking change re: std::mutex is documented here...
https://github.com/microsoft/STL/wiki/Changelog#vs-2022-1710
If you really don't want to static link, this is the workaround...
#define _DISABLE_CONSTEXPR_MUTEX_CONSTRUCTOR
But I updated all my projects to static link from now on. Only a few use std::mutex and most do not but I figured I would protect myself from getting burned by anything else in future.
I would highly recommend against using static linking. There is a limit in number of DLLs the player can load that are linked that way, which was already a problem many years ago. If you must use std::mutex and don't want to use older toolchain or the compatibility setting, then of course that is your only option. Also note that new foobar2000 releases should bundle the latest runtime at the time of release.
Thanks! That's helpful.
Related to the thread title if not the first post itself....an upcoming release (17.12) is dropping support for targetting windows 7.
https://github.com/microsoft/STL/pull/4742
That was exactly my case: I wanted to use latest C++ features and third-party libraries that rely on those features, but foobar2000 release cycle (and thus toolchain update cycle) was much slower than VS updates - sometimes it took more than a half a year to catch up. Also, I might be mistaken, but I think fb2k does not (did not?) even always use the latest version of toolchain.
(...)upcoming release (17.12) is dropping support for targetting windows 7.
A major oof... Not that it was unexpected, but still...
They've changed their minds on dropping win7 targetting in VS2022.
Before: "gotten approval from my bosses and boss-like entities"
After: "My ultrabosses have decided" xDDD
But it is getting nuked in the next major version
Thankfully, probability of "next major version" appearing in the near future is quite low (because MS/VS management understandably do not want to break back-compatibility).
Thanks for finding all these tit-bits :)
TheQwertiest, they follow roughly 3-year release cycle and most probably the next major version will be released this or next year.
I think you are confusing two things: VS IDE release and MSVC compiler major version change (https://learn.microsoft.com/en-us/cpp/overview/compiler-versions?view=msvc-170#version-macros).
They've been keeping major version the same for at least 9 years.
And while I believe that compatibility break *will* happen one day, I have huge doubts that it will be done any time soon, because there is just no good enough reason to justify such a huge break for their business customers.
Nevermind, it's me who can't read:  "dropping support has been approved for the 18.0 Preview", i.e. it's VS IDE and not compiler version
Current MSVC compiler version is v14.3. They dropped Windows XP in a minor update from v14.0 to v14.1, nothing prevents them from dropping Windows 7 in v14.4. In fact, the MSVC developers are considering to make an incompatible update for C runtime for a few years already, so it might be a major update. It's just their ultrabosses not allowing to do it yet. BTW, they also want to make the runtime open source, waiting for another ultrabosses approval =)
