Topic: foo_uie_webview (Read 75849 times) previous topic - next topic
0 Members and 10 Guests are viewing this topic.
Re: foo_uie_webview
Reply #502
foo_uie_webview v0.2.0.0
No changes since alpha5.
You can download it from GitHub and from the Component repository.
Re: foo_uie_webview
Reply #503
Logic question.
I'd like to get the album artwork (front covers) from a library selection (facets). Playlist would be Facet selection. Is it possible?
Re: foo_uie_webview
Reply #504
Reply #384 – 2024-09-04: https://hydrogenaud.io/index.php/topic,126042.msg1050191.html#msg1050191
Template from Yeyo with Track Infos and Run Services (Toggle On/Off).
Thanks to Yeyo, Julero and mjm716.
-- Star ratings are displayed if you have rated your track
-- Playback time remaining
-- Composer (Metadata)
-- No question mark display
@Jacob91
foo_uie_webview v0.2.0.0 (and v0.2.0.0-alpha5)
It doesn't work. The CD won't spin.
v0.2.0.0-alpha4 works.
foobar2000 v2.24 : 32-bit | 64-bit
foobar2000 v1.6.8
Windowsa 11 24H2
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD620S, SENNHEISER HD 490 Pro Plus, beyerdynamic DT 1990 PRO, HiFiMAN Edition XS, Bowers & Wilkins P7, FiiO FT5, 水月雨 (MOONDROP) 空鳴 - VOID, Nakamichi Elite FIVE ANC, SONY WH1000XM5 (made a Upgrade/Balanced Cable by myself)
Re: foo_uie_webview
Reply #505
@Jacob91
foo_uie_webview v0.2.0.0:
foobar2000 v1.6.8
Windowsa 11 24H2
For that matter, the original version of yeyo doesn't work either.
My tool does work though.
Re: foo_uie_webview
Reply #506
I did a complete en plein.
Three major issues, one with foobar2000 with the .png artwork management not being able to properly handle the png file size.
One is with vu meter not handling audio files tagged with images and now foo uei web view.
It seems perfect to me.
I also add the easy lyric crash.
Re: foo_uie_webview
Reply #507
OT.......
And what I would like to understand at this point, and the intervention of the author of foobar2000 would be appreciated, with what size I have to tag the audio files.
Because png is not possible to use it and this creates problems with disc. Jpgs are lighter but these also create problems with foo_vis_vumeter, minor but they are there.
Same thing for waveform minibar and for seek bars.
Basically, in order for there to be no problems, one must not tag the audio files with images.
My tool that is based on tagged images has no problem.
Re: foo_uie_webview
Reply #508
OT.......
You're both all over the place.
First off, the entire discussion really belongs here: https://hydrogenaud.io/index.php/topic,126243.0.html
Regarding image file size, did you check Prefs>advanced>Album art: maximum external art size? also embedded vs external?
Re: foo_uie_webview
Reply #509
OT.......
But how confused.
Apart from the fact that in advanced preferences I do not combine absolutely anything and the image management of foobar2000 that does not work well and enters into crisis, as soon as you put animation plugins such as vu meter, seekbar waveform and I am on 64 bit. I realize that I am OT and I close.
Re: foo_uie_webview
Reply #510
Why does the spinner not work in the latest version of foo_uie_webview plugin?
Re: foo_uie_webview
Reply #511
@sq68
Already posted
Reply #504 https://hydrogenaud.io/index.php/topic,126042.msg1055540.html#msg1055540
Re: foo_uie_webview
Reply #513
also is there a reason   window.location.reload();
is no longer working? alternative?
window.location.reload() works fine for me.
Re: foo_uie_webview
Reply #514
@Jacob91
foobar2000 v1.6.8
Windowsa 11 24H2
Now, it works with foo_uie_webview v0.2.0.0
Thanks to pqyt.
Re: foo_uie_webview
Reply #515
@Jacob91
Perfect, thank you.
Re: foo_uie_webview
Reply #516
@Jacob91
foobar2000 v1.6.8
Windowsa 11 24H2
I went to look at the author's changelog:
Changed: Breaking Change All properties, methods and callbacks to use camelCase convention. (alpha5)
The plugin author changed the naming convention of the callback function, and only needs to capitalize the On... Changed to lowercase on... to get back to work.
For example: OnPlaybackTime(time) is changed to onPlaybackTime(time)
Re: foo_uie_webview
Reply #517
@ yeyo
I made the changes to the spin disc of your version and they are now compatible with the latest version of the foo_uie_webview plugin.
I didn't post it out of fairness to you.
Re: foo_uie_webview
Reply #518
@ yeyo
Feel free to share, I'd love to!
Re: foo_uie_webview
Reply #519
@ yeyo
Ok tell me if it's okay. I changed the background color, image path and icon management beyond opening the container box.
Re: foo_uie_webview
Reply #520
There are huge problems it doesn't update the images it wants forced refreshes return to alpha 4.
Thank goodness for the back-ups of the spin disc modules.
My tools are also affected, I don't intend to go crazy changing all the codes again, I'll stick with alpha 4.
Re: foo_uie_webview
Reply #521
@ yeyo
Do not download this version because it does not update the images.
@ yeyo if you can post your updated version, without runservice and info track, which I'm not interested in, and I really don't understand it, you'll do me a favor.
Thank you.
Re: foo_uie_webview
Reply #522
From alpha 4 to alpha 5 I no longer update anything, I don't update images, data or who knows what else. Since I broke myself profusely, because it involves editing over 10 scripts. I greet you, it was a pleasure. Two months of work wasted. Thank you very much.
Re: foo_uie_webview
Reply #523
@ yeyo
Thank you.
Note the case of the refresh function. After reading your template, the function name is "function Refresh()" and the place where it is called is ”refresh()", please change it to ”Refresh()“.
Re: foo_uie_webview
Reply #524
@ yeyo
Thank you.
Maybe it was just this. A way of things has changed Changes to Functions and Properties
Methods:
GetArtwork should be getArtwork.
GetFormattedText should be getFormattedText.
Callbacks:
OnPlaybackStarting should be onPlaybackStarting.
OnPlaybackStop should be onPlaybackStop.
OnPlaybackPrevious should be onPlaybackPrevious.
OnPlaybackNext should be onPlaybackNext.
To say I'm angry is an understatement. But for what then for this Changed: Returned JSON objects now use camelCase casing. (alpha4)
Changed: *Breaking Change* Callbacks follow the Category-Noun-Verb naming convention. (alpha5)
Changed: *Breaking Change* All properties, methods and callbacks to use camelCase convention. (alpha5)
Changed: *Breaking Change* The parameter list of most callbacks has been expanded. (alpha5)
I have 13 scripts to edit never never never.......
