Topic: Tagging via properties no longer works (Read 248 times) previous topic - next topic
I use Foobar2000 in a 32 bit wineprefix on Arch Linux.
It's hard to say when this bug appeared, but it definitely carried over from before I created a clean wineprefix recently, and I did not have this problem before version 2.
The problem is that I cannot tag files via context-menu -> properties. When I edit anything and hit "apply", the view reloads and displays the previous tags again. "Ok" doesn't work either.
All my music is on an NTFS filesystem mounted with full read/write permissions.
There is no error being displayed in the console.
For some reason I cannot go into safe mode. When I try to launch into safe mode, I just get an error popup saying "Internal error - one or more of the installed components have been damaged; please run the foobar2000 installer again." But reinstalling it doesn't help. Why would safe mode fail to launch because of "damaged components" when its whole point is to disable components?
F2k version: 2.1.5
Wine version: 9.6-1
Codec of files I was using for testing:
Tool : LAME3.99r
Tag type : id3v2.3|id3v1
Re: Tagging via properties no longer works
Nevermind, the problem seems to depend on the wineprefix after all. I don't know what part of it is at fault, but it's definitely not due to foobar2000. Thread can be closed I suppose.
Edit: It was the Windows version selected in winecfg.  ::)
Win7 breaks tagging. Win10 doesn't. God knows why.
