Topic: [MAC] Problems with file operations on SMB share (Read 700 times) previous topic - next topic
I'm using the latest foobar2000 version (2.7 preview 2024-05-06) and have encountered a problem with file operations. My music resides on an SMB share. If I use file operations to move files inside my media library, then foobar2000 doesn't recognize that files are already present and match the pattern.
Here are the files on the share:
X
Here's foobar2000 wanting to move them although they're already there:
X
And here's foobar2000 not exhibiting this behaviour (as expected) when the media library is on a local disk:
X
Re: [MAC] Problems with file operations on SMB share
Okay, this is not limited to SMB shares, it also happens with an external drive which is directly connected to my Mac.
External drive:
X
Local drive:
X
So, nobody else has this issue?
Problem confirmed, thanks for reporting.
Fixed in today's build.
Works. Thank you.
