Topic: "Them Changes" spectrogram differences -- what's gong on here? (Read 820 times) previous topic - next topic
I was checking for a lossy -> lossless transcode and this artifact showed up.  I don't hear a difference (mono bluetooth speaker) b/w the two and I can't speak to the sources., but they both appear to be flac.
Can anyone explain what is going on, i.e., why these look so different?
$ mi 1970\ -\ Them\ Changes/01\ -\ Them\ Changes.flac Buddy\ Miles\ -\ Them\ Changes\ \(1970\,\ 2003\)⭐FLAC/Buddy\ Miles\ -\ 1\ -\ Them\ Changes.flac
General
Complete name                            : 1970 - Them Changes/01 - Them Changes.flac
Format                                   : FLAC
Format/Info                              : Free Lossless Audio Codec
File size                                : 22.5 MiB
Duration                                 : 3 min 19 s
Overall bit rate mode                    : Variable
Overall bit rate                         : 943 kb/s
Album                                    : Them Changes
Track name                               : Them Changes
Track name/Position                      : 01
Performer                                : Buddy Miles
Genre                                    : Fusion, Funk
Recorded date                            : 1970
Cover                                    : Yes
Cover type                               : Cover (front)
Cover MIME                               : image/jpeg
Audio
Format                                   : FLAC
Bit rate mode                            : Variable
Bit rate                                 : 916 kb/s
Channel(s)                               : 2 channels
Channel layout                           : L R
Sampling rate                            : 44.1 kHz
Bit depth                                : 16 bits
Compression mode                         : Lossless
Stream size                              : 21.8 MiB (97%)
Writing library                          : libFLAC 1.1.4 (UTC 2007-02-13)
General
Complete name                            : Buddy Miles - Them Changes (1970, 2003)⭐FLAC/Buddy Miles - 1 - Them Changes.flac
Format                                   : FLAC
File size                                : 34.0 MiB
Duration                                 : 3 min 21 s
Overall bit rate                         : 1 415 kb/s
Track name/Position                      : 1
Audio
Format                                   : FLAC
Bit rate                                 : 1 415 kb/s
Bit depth                                : 16 bits
Stream size                              : 34.0 MiB (100%)
Writing library                          : libFLAC 1.4.2 (UTC 2022-10-22)
Re: "Them Changes" spectrogram differences -- what's gong on here?
Seems like one of of them is remastered version.
Also, swapped channels?
Also noticed this. The OP is using a mono speaker so they would sound the same.
