HALAC 0.2.8
Encoders, Decoders, Libraries and Player (Both Windows and Linux)
https://github.com/Hakan-Abbas/HALAC...ssion/releases
https://github.com/Hakan-Abbas/HALAC-Audio-Player
![X](https://hydrogenaud.io/index.php?PHPSESSID=vl7nv8rr8i5ultn4c2juum2lmo&action=dlattach;attach=30805;image)
//HALAC 0.2.8 Library Function Prototypes
extern "C" HALAC_PLAYER_API const bool __stdcall CHECK_HALAC(const char* data);
extern "C" HALAC_PLAYER_API const char* __stdcall GET_HALAC_VERSION();
extern "C" HALAC_PLAYER_API char* __stdcall GET_WAV(const char* data, unsigned short thread_count);
extern "C" HALAC_PLAYER_API char* __stdcall GET_WAV_FRAME(const char* data, unsigned int first_frame_no, unsigned int last_frame_no, unsigned short thread_count); // 0...(frame_size -1)
extern "C" HALAC_PLAYER_API char* __stdcall GET_RAW_FRAME(const char* data, unsigned int halac_frame_size, unsigned int wav_frame_size, unsigned char halac_mode, unsigned short channel_count, unsigned short sample_bit, unsigned short thread_count);
extern "C" HALAC_PLAYER_API char* __stdcall GET_WAV_HEADER(const char* data, unsigned short header_size);
extern "C" HALAC_PLAYER_API const unsigned short __stdcall GET_WAV_HEADER_SIZE(const char* data);
extern "C" HALAC_PLAYER_API const int __stdcall GET_METADATA_SIZE(const char* data); // Negative values give the length of metadata at the end of the file.
extern "C" HALAC_PLAYER_API const char* __stdcall GET_METADATA(const char* data, int metadata_size);
extern "C" HALAC_PLAYER_API const unsigned char __stdcall GET_HALAC_MODE(const char* data); // normal or fast
extern "C" HALAC_PLAYER_API const unsigned long long __stdcall GET_WAV_FILE_SIZE(const char* data);
extern "C" HALAC_PLAYER_API const unsigned long long __stdcall GET_WAV_DATA_SIZE(const char* data);
extern "C" HALAC_PLAYER_API const unsigned short __stdcall GET_CHANNELS(const char* data);
extern "C" HALAC_PLAYER_API const unsigned int __stdcall GET_SAMPLE_RATE(const char* data);
extern "C" HALAC_PLAYER_API const unsigned short __stdcall GET_BIT_COUNT(const char* data);
extern "C" HALAC_PLAYER_API const unsigned int __stdcall GET_HALAC_FRAME_COUNT(const char* data); //Number of compressed blocks
extern "C" HALAC_PLAYER_API const unsigned int* __stdcall GET_HALAC_FRAME_SIZES(const char* data); // Lengths of compressed blocks
extern "C" HALAC_PLAYER_API const unsigned int __stdcall GET_WAV_FRAME_SIZE(); // 1024*1024 bytes except for the last frame
extern "C" HALAC_PLAYER_API const unsigned int __stdcall GET_WAV_LAST_FRAME_SIZE(const char* data);
extern "C" HALAC_PLAYER_API void __stdcall DELETE_WAV_MEMORY();
