Topic: HALAC (High Availability Lossless Audio Compression) (Read 26798 times) previous topic - next topic
0 Members and 9 Guests are viewing this topic.
Re: HALAC (High Availability Lossless Audio Compression)
Reply #125
Post the new version [0.2.8 maybe] of the encoder and decoder with lossyWAV support (lossyHALAC output format).
I can't make any firm promises for 0.2.8, but I might add LossyWAV support for the next version. And since a special work will be required for an option such as "LossyHALAC", I can think about this topic later.
Reply #126
How did you do lossyHALAC in this image: https://hydrogenaud.io/index.php?action=dlattach;attach=30749;image?
Maybe with correct block size in lossyWAV, we could achieve lossyHALAC. With the default block size, it's not working correctly.  ???
Reply #127
How did you do lossyHALAC ...
I do not have full information about the LossyWAV structure and I haven't fully examined. And I didn't do anything specifically for the content. I only disabled the prediction phase required for the lossless mode. However, I did not activate it for 0.2.8.
Considering the results in the list, the HALAC offers enough compression even in this form. For better results, the data structure needs to be examined and certain adaptations are required. Of course, time is necessary for this.
Reply #128
If I understood it right, LossyWAV's default block size choice of slightly below twelve milliseconds, is to allow for swift changes in the number of decimated LSBs. Bigger blocks would mean you would have to keep that constant over a longer time. 512 samples in LossyWAV and say 1024 in a compressor that employs a per-block wasted bits strategy, would restrict it to choosing the "worst of two".
When I suggested to facilitate LossyWAV, I didn't know whether it would be easy for HALAC to employ a user-selectable block size.
FLAC does a trick that for some signals improve compression by quite a lot, namely the partitioning with different Rice parameters. If a block is size K*2^N, then a partition order of N means that the residual coding parameter is changed every K samples; immediately after K samples there are four bits with a Golomb-Rice exponent. This instead of a low block size which would require frame headers.
Of course, if one did intend a lossy usage like this, one could have partitioned it with different wasted bits too.
The partitioning is one reason why FLAC does better with block size 4096 than 4095. Sure if you don't use the same residual coding methods, YMMV - but we know certain signals where the advantage of rapidly changing a residual coding parameter can actually make FLAC outcompress any OptimFROG.
Reply #129
Thank you for the valuable information you gave, Porcus.
Since Flac or some other codecs act according to Rice encoding, there may be such exceptions based on block size. however, HALAC may act structurally more flexible. Rice coding definitely has strengths on audio data. Actually, I was thinking of partially using Rice coding in the next versions, but right now I'm trying to complete the DLL and Player issue in detail with 0.2.8 (as long as I can find the opportunity and concentrate).
Reply #130
I know you are using some 2010s algorithm, which is much newer than anything Golomb-Rice, but my point was not the particular method - rather, that FLAC has this way of partitioning blocks into different coding parameters without new block overhead.
If we compare to other codecs' "preset choices", all for CDDA, then ALAC defaults to 4096 samples, ffmpeg's FLAC to 4608, TAK's largest -p4 modes have 0.25 seconds blocks, WavPack's is 0.5 I think down from 1 in WavPack 4, TTA (no measure of quality) a bit above 1 second, OptimFROG up to several and Monkey's ... I think the "Insane" mode is closing in on half a minute, but Insane is insane and the developer recommends not to use it.
So FLAC is already one which doesn't use big blocks, but it so turns out that the option to change parameters even more often, does improve.
Whether anything such is any priority for HALAC, which (in my view) is about showing what a new compression algorithm can do fast ...
Reply #131
If the "k" parameter can be identified as adaptive in Rice coding, the block size is not important. Of course, this will also reduce the transaction speed. However, if the "k" parameter per block is to be determined, it is useful to be small against changes.
On the other hand, neither too small nor too large blocks for other statistical entropy encoders (Huffman, Arithmetic Coding or ANS) do not usually do good results. Of course, I'm talking about "-order 0". Because there is an additional load for each block. That is, it is more than Rice coding. It also reduces the process speed. If larger blocks are selected, the alphabet may grow this time (there may be an increase in the number of symbols). In other words, the distortion in the distribution may become more uniform, which is not desired.
This is the case for HALAC for now. 4096 samples in -normal mode and 8192/16384 samples are used in -fast mode. It may also be in any size, provided that it does not exaggerate. Statistical entropy encoders are not very efficient on audio data, contrary to popular belief. It is not easy to make it efficient. This means an extra processing load.
I don't share the results of the things I don't normally complete, but I tried to roughly show the difference between the following Rice coding (my own implementation) and the ANS coding. The Rice parameter was calculated very simple. Even if the situation does not change in terms of speed, this is not valid for all kinds of audio data in terms of compression rate.
BUSTA RHYMES(i7 3770k, 20 tracks, Total 829,962,880 bytes)
HALAC NORMAL 1 Thread (ANS) : 4.32 sec, 574,161,601 bytes
HALAC NORMAL 1 Thread (RICE): 3.66 sec, 567,469,774 bytes
Reply #132
Your first attempt at Rice improves more than a percent at compression and thirteen at speed? :-o
(IIRC, FLAC computes the Rice parameter as the average residual. It is close to optimal.)
Reply #133
Yes, there is acceleration in my experiments in any case. Especially in low entropy data, the efficiency of Rice coding decreases.
The JPEG-LS image format also uses Rice encoding. And calculates the parameter "k" retrospectively with a certain average. I calculated it in a similar way. Of course, the smaller the block size, the more accurate "k" values can be obtained. But in this case, we also have a lot of side information.
The adaptive method is better. I know you're doing a good job with my image compression studies. In this case, our work performance decreases significantly. For the most appropriate situation, this issue needs to be studied specifically.
Reply #134
HALAC 0.2.8
Encoders, Decoders, Libraries and Player (Both Windows and Linux)
https://github.com/Hakan-Abbas/HALAC...ssion/releases
https://github.com/Hakan-Abbas/HALAC-Audio-Player
X X
//HALAC 0.2.8 Library Function Prototypes
extern "C" HALAC_PLAYER_API const bool __stdcall CHECK_HALAC(const char* data);
extern "C" HALAC_PLAYER_API const char* __stdcall GET_HALAC_VERSION();
extern "C" HALAC_PLAYER_API char* __stdcall GET_WAV(const char* data, unsigned short thread_count);
extern "C" HALAC_PLAYER_API char* __stdcall GET_WAV_FRAME(const char* data, unsigned int first_frame_no, unsigned int last_frame_no, unsigned short thread_count); // 0...(frame_size -1)
extern "C" HALAC_PLAYER_API char* __stdcall GET_RAW_FRAME(const char* data, unsigned int halac_frame_size, unsigned int wav_frame_size, unsigned char halac_mode, unsigned short channel_count, unsigned short sample_bit, unsigned short thread_count);
extern "C" HALAC_PLAYER_API char* __stdcall GET_WAV_HEADER(const char* data, unsigned short header_size);
extern "C" HALAC_PLAYER_API const unsigned short __stdcall GET_WAV_HEADER_SIZE(const char* data);
extern "C" HALAC_PLAYER_API const int __stdcall GET_METADATA_SIZE(const char* data); // Negative values give the length of metadata at the end of the file.
extern "C" HALAC_PLAYER_API const char* __stdcall GET_METADATA(const char* data, int metadata_size);
extern "C" HALAC_PLAYER_API const unsigned char __stdcall GET_HALAC_MODE(const char* data); // normal or fast
extern "C" HALAC_PLAYER_API const unsigned long long __stdcall GET_WAV_FILE_SIZE(const char* data);
extern "C" HALAC_PLAYER_API const unsigned long long __stdcall GET_WAV_DATA_SIZE(const char* data);
extern "C" HALAC_PLAYER_API const unsigned short __stdcall GET_CHANNELS(const char* data);
extern "C" HALAC_PLAYER_API const unsigned int __stdcall GET_SAMPLE_RATE(const char* data);
extern "C" HALAC_PLAYER_API const unsigned short __stdcall GET_BIT_COUNT(const char* data);
extern "C" HALAC_PLAYER_API const unsigned int __stdcall GET_HALAC_FRAME_COUNT(const char* data); //Number of compressed blocks
extern "C" HALAC_PLAYER_API const unsigned int* __stdcall GET_HALAC_FRAME_SIZES(const char* data); // Lengths of compressed blocks
extern "C" HALAC_PLAYER_API const unsigned int __stdcall GET_WAV_FRAME_SIZE(); // 1024*1024 bytes except for the last frame
extern "C" HALAC_PLAYER_API const unsigned int __stdcall GET_WAV_LAST_FRAME_SIZE(const char* data);
extern "C" HALAC_PLAYER_API void __stdcall DELETE_WAV_MEMORY();
Reply #135
first link from your latest post gives out a 404 page (obvious reference to Star Wars IV scenery with github mascot cosplaying Obi-Wan Kenobi)
Reply #136
The text editor of the forum where the data was entered must have detected the link in this way by mistake. Corrected ¯\_(ツ)_/¯
https://github.com/Hakan-Abbas/HALAC-High-Availability-Lossless-Audio-Compression/releases
Reply #137
ok, this new link actually works now. thanks.
