Topic: About Remote Control on smartphone (Read 2976 times) previous topic - next topic
Hello everyone,
For about a week I have been trying everything to try to get the foobar controller running on a Windows 11 PC through an iPhone 14 or through a recent Android smartphone.
I tried both with portable installations and in the OS, both the 32bit and x64 versions
Monkey mote lite does not connect, even when configuring manually by entering the PC's IP address and trying to connect manually, I tried to install Bonjour on the PC separately, but nothing...
I have read about some apps which however are not available on both Android and iPhone such as: foobar2000 controller, Beefweb Remote Control, FoobarCon Pro (just for windows device)
What do I really need to do to control foobar2K from a smartphone.
Are there step by step guides?
Thank you
Re: About Remote Control on smartphone
Did you allow foobar2000 to connect on the firewall side?
This is most likely the reason for not being able to connect.
The control device I am using is below.
iOS > foobar2000 (32bit, 64bit)
MonkeyMote for foobar2000
MonkeyMote for foobar2000 HD
Android > foobar2000
foobar2000 controller PRO (32bit, 64bit)
MonkeyMote Music Remote (32bit, 64bit)
foobarCon PRO (32bit)
Japanese wiki
https://foobar2000.xrea.jp/?foobar2000+mobile#y59198cd
https://foobar2000.xrea.jp/?General+64bit#be7b2131
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD620S, SENNHEISER HD 490 Pro Plus, beyerdynamic DT 1990 PRO, HiFiMAN Edition XS, HIFIMAN ANANDA, Bowers & Wilkins P7, FiiO FT5, FiiO FT1 Pro, 水月雨 (MOONDROP) 空鳴 - VOID, SONY WH1000XM5 (made a Upgrade/Balanced Cable by myself)
Thank you Air KEN, I will try soon  :)
Preparation:
Windows Security:
Firewall & network protection
Allow an app through firewall
Change settings
foobar2000
Private and Public → Check both
foobar2000 controller PRO and foobarCon PRO:
HTTP Control (foo_httpcontrol_0_97_28.fb2k-component)
foobar2000\profile\foo_httpcontrol_data\foobar2000controller
foobar2000\profile\foo_httpcontrol_data\foobarCon
foo_httpcontrol_data.zip: https://mega.nz/file/hX1UEYqb#N_KnYobKAQ3NuWgAEUy7PI8CGISLphWRKgFS0I6oL7k
foobar2000 controller: for example
Preferences > Tools > HTTP Control > Listen on 192.168.1.2:8888 (IP Address)
Start server Open http://192.168.1.12:8888
Username and Password
Start server Open http://192.168.1.12:8888 ← Click
foobar2000 controller start
Settings > Open the server wizard
Auto
IP Address tap
name and User and Password → Add
name IP Address tap
MonkeyMote: for example
foo_monkeymote install
Preferences > Tools > MonkeyMote > Server enabled check and Password
Android MonkeyMote > Conenctions ... > Use Automatic Discovery or Add Manual Entry
name and IP Address tap
I prefer install x64 version of FoobBar2K in portable mode...  is it tested in this config?
Thank  you
foobar2000 v2.1 preview 2023-11-09 : 32-bit | 64-bit
-Standard installation
-Portable installation
foobar2000 v2.0 : 32-bit | 64-bit
foobar2000 v1.6.17
Linux Mint
Linux Ubuntu
I haven't received an answer about whether you allowed foobar2000 in your firewall.
This is the most important thing.
foobar2000 controller PRO: for example
Open the server wizard 3/5 choice → "Auto". 4/5 Automatic search icon tap.
If you cannot connect here, it is a problem with the firewall program connection permission settings.
