Topic: Flex DSP (Read 16122 times) previous topic - next topic
Re: Flex DSP
@anamorphic
Thanks for the great advice!
No, I don't understand. orz
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD620S, SENNHEISER HD 490 Pro Plus, beyerdynamic DT 1990 PRO, HiFiMAN Edition XS, HIFIMAN ANANDA, Bowers & Wilkins P7, FiiO FT5, FiiO FT1 Pro, 水月雨 (MOONDROP) 空鳴 - VOID, SONY WH1000XM5 (made a Upgrade/Balanced Cable by myself)
Re: Flex DSP
@anamorphic
$if($strcmp(%output_dsp_preset%,'Flex DSP'),[ : %track_flexdsp%],)
Yes, it's simple.
In Flex DSP mode, Tracks (Albums) that do not contain the %track_flexdsp% tag can be displayed without any unnecessary content.
・Somehow I keep stumbling over the simplest things.
Output Info 1.2.3 (foo_outinfo)
This is worth it to @Case for adding %output_dsp_preset%.
Thanks. @anamorphic and @Case
Re: Flex DSP
Hi, I have a problem, please have a look.
in my understanding, PeakOK, Bitreduce and then Limiter should be subsequently executed. Or is there a misunderstanding on my end?
PeakOK is an empty chain. Bitreduce has "mda dither" with Bitrate reduction to 20. Limiter has "Advanced Limiter".
I cannot judge on advanced limiter, but mda dither is definitely not running (there should be a noticable flac file size difference). If I add mda dither into the converter chain after Flex DSP, I can clearly see the difference in file size (also Truepeak scanner measures 20 bits then).
X
Re: Flex DSP
RESOLVED. After further testing I noticed my testing was flawed. The processing here works.
