Topic: How to MOVE fb2k to new PC AND UPGRADE from v1.2.9 to v2.0 ? (Read 1082 times) previous topic - next topic
If you type my subject line into Google you get:
"Launch foobar2000 on your new computer so it will create the necessary folders, but don't bother running the setup wizard. On your old computer, navigate to . \Users\Your User\AppData\Roaming\foobar2000. Copy all of these files into the same location on your new computer."
I installed foobar2000 on my new PC and it now has v2.0.  However, my old PC has V1.2.9.
The new Appdata folder for the new PC has  library-v2 and playlists-v2 folders. Also, the new PC's playlist-v2 folder had an index.txt file while my old PC's playlist folder has an index.dat file.
Do I need to upgrade foobar on my old PC before I will be able to replace the appdata folder on the new PC?
Any help will be greatly appreciated.
MOD changed Subject/Title (was: Moving foobar2000 from an old Windows PC to an new WIndows 10 PC)
Re: How to MOVE fb2k to new PC AND UPGRADE from v1.2.9 to v2.0 ?
What you are really asking is "how to upgrade FB2K v1.2.9 to v2.0" (which would be a much clearer title), Win10 has no bearing on this.
I'm sure somebody more knowledgable than me will advise, but in the mean time you could set up v2 as a portable installation and experiment with what happens when you import your existing configuration files.  You could also try v1.6.
I uninstalled v2.0 and installed v.1.6 as suggested.  Then I deleted the existing AppData folder and replaced it with that from my 1.2.9 version.  That did not seem to work. :(  No playlists.  Missing plugins.  I thought about trying to add components to the 1.6 version but instead...
I overwrote both the foobar2000 program and AppData folders with my v1.2.9 versions and I seem to have a perfectly fine working v1.2.9 copy.
The question now is: is it worth trying to upgrade?
Installed or portable?  It's much easier to fiddle around with a portable install, the files are not spread all over the place.
