Topic: Modern tracks in mono? (Read 6703 times) previous topic - next topic
Have any of you heard of modern tracks (2000s-present) that were recorded in mono instead of the standard stereo? Is there a reason why the artist/band would record in mono?
LAME: -f -V 0 -Y
 Xing: -V150 -X2 -U2 -HF-1 -TX0
Re: Modern tracks in mono?
Production would be easier (lazier?)
Let's say you have a Solo Artist, with just guitar or vocals, Or maybe just a single instrument, a piano. It's a lot easier to go thru production without worrying about stereo, you setup the few mics that you need, keep everything centered and you are done with that part.
But for most bands a simple stereo separation of instruments, seems to give better results with the audience. It sets a stage where it's easier to imagine the band playing in front of you. You wouldn't have all the instruments clumped up in the dead center of a stage, so using stereo reflects that.
And then you have even more meticulous use of stereo for setting up the stage, for example Bohemian Rhapsody by Queen.
It's a tool artist have at their disposal. Tends to gives better results with the audience. So why not use it?
Going back to a single instrument a piano. You can even stereo separate by pitch. Have the lower octaves with a slight left bias and vice-versa.
Aesthetics is the only reason to record in mono. Contary to the person above, I've not been in a mixing / mastering studio for a decade who cared about mono performance. No one will compromise stereo for mono compatible recordings any more..
I am streaming mono using Chromecast to a single loudspeaker. From pure laziness, I am simply picking one side of the stereo-mix (often simultaneously streaming stereo to my living room).
Listening to one side of the stereo mix while making dinner, while hearing the entire mix from the other room is ... quite interesting at times.
Making sure something sounds good on phone speakers is something a sound engineer I talked to said he does because that's how a subset of the audience will listen. Wouldn't be surprised if some modern pop music mixes at least downplayed the stereo aspect so it sounds similar/familiar on everything including crappy phone speakers and store speakers for that reason. Full mono would be kind of crazy, maybe there's a genre that would sound fine in mono but especially metal gets so much mileage from playing with stereo that it would suffer heavily.
Punk wouldn't be terrible in a mono-only world, a lot of that has a muddy low effort sound as a feature.
They are not true mono.
Everything is divided into left/right channels. (20Hz/20Hz) = 44100 Hz
EZ CD Audio Converter
Necro, but I believe it is apropos: Margerine Eclipse by Stereolab arguably qualifies.
Margerine Eclipse was mixed with full stereo separation – or as Stereolab termed it, in "dual mono". For every song, the band made two recordings – each with a different arrangement – then created a final mix by synchronising both recordings together, with one on the left channel and the other on the right channel.
As a result, either channel, if played back in isolation, is effectively a self-standing mix in its own right.
"Jazz Sabbath - The 1968 Tapes (2024)" has a mono variant.
before I ran it on headphones, I did not notice it's in mono on speakers, but it is, L/R channels are identical.
it also sounds better than the stereo variant in some ways, and the stereo variant isn't bad at all.
Demos and very small artists (bedroom artists) may only have one microphone to record.
they might also choose to record twice and/or add reverb (might not always help, but sometimes it might)
also generally if there are multiple mono tracks, panning them around differently is a simple way to have an actual stereo mix
