Topic: Windows Mixer... alternative? (Read 12759 times) previous topic - next topic
  • Mechrekt
Is there a software that can substitute the default windows mixer?
I need it to emulate an equalizer, for applications that doesn't have it. (It's not the case of winamp for example).
- Aetherna Official Webpage: www.aetherna.com
- (sorry for my english  :O) )
  • picmixer
Isn't it so that most Souncarddrivers should be able to do this for you?  They might not replace the mixer entirely, but at least offer some sort of extended control panel. Guess it depends on the Soundcard though how good the EQ is.
Am not sure wether thats exactly what you are looking for though.
  • Last Edit: 21 August, 2003, 09:23:26 AM by picmixer
I have yet to see a card whose drivers have built-in EQ.
ruxvilti'a
  • lucpes
Turtle Beach Santa Cruz  It's actually a hardware eq.
  • lexor
my Live! has it in the drivers, it's standard for all Creative cards. M-audio cards don't as well as many others.
The Plan Within Plans
  • picmixer
My Terratec as well.  Guess it depends on what model card you have then.
  • Last Edit: 21 August, 2003, 04:06:13 PM by picmixer
EQ for SBLive? Which drivers and card? (except kX drivers of course, I know about them...)
BTW, which TerraTec card it is?
  • Last Edit: 21 August, 2003, 07:21:46 PM by AstralStorm
ruxvilti'a
  • Lyx
at least my (Terratec) xFire 1024 (an old card) has it. From my experience, i'd say it depends on the chipset used, not the model. For example, i know that other cards which use the same chipset as my card, also have an EQ built into the drivers.
  • lexor
/me smacks himself on the head,
my Crative's Live! drivers also installed AudioHQ, in there if I go to Speaker then EAX tab, there are a boat load of presents, but you are right no manual EQ.
No, there really is a patch for Parametric EQ on SBLive AFAIK... (Liveware 2, 2.1 and 3)
ruxvilti'a
  • Mordejai
I guess you mean "all the expensive Creative cards" when you say "all Creative cards", because PCI128 and similar models don't have that.
  • Madrigal
You could try Sound Control, available here.
Regards,
Madrigal
Thanks for that link Madrigal.  At first glance, that software appears to be great!
Dex
Just what I was looking for.
  • Last Edit: 23 August, 2003, 07:51:08 PM by Dex4now
  • Artemis3
The on board cheapo Realtek 5.1 ALC650 of my MSI motherboard has one at the "Sound Manager". It also has fancy reverb and pitch settings, and "Envirements".
She is waiting in the air
  • _Shorty
  • Banned
hmm. My Aureal SuperQuad something-or-other card had an EQ, as does my Hercules Fortissimo III, as does my Nforce2's SoundStorm or whatever they call it. No idea which of them, if any, were hardware EQs on the card itself or just in the drivers.
  • picmixer
Sorry about the slightly late answer.  Completely overlooked this thread the last days.
It is a Terratec Six Pack.
  • Last Edit: 24 August, 2003, 06:24:24 AM by picmixer
  • ScorLibran
  • Banned
I'm looking for the same thing.  I want a freeware realtime output EQ that "sits" between any playback source (WinAMP, CD playback, Quintessential, etc.) and my soundcard.  A "system EQ", in essence.  My soundcard is an Echo Indigo, and it does have its own console software which seems to have replaced my Windows mixer.  It has some channel managements functions (level, balance, muting) but no equalization.  My OS is WinXP.
I looked at Sound Control, but it's only seems to configure hotkeys for channel management functions, but I couldn't find any EQ function in it.  I tried using an internet search for +freeware +eq, and looked through the first 70 results that it came up with, but to no avail.  Found one, LizzEQ, that turned out to be a Cubase/VST plug-in.  I need one that I guess would be a Windows XP plug-in(?).  I did find a few non-freeware options, but I'd rather get a freeware solution if one exists.
Preferably something with at least 10 bands per channel (the more the better), at least +/-12 dB adjustment range (+/-15 dB would be even better), with as good/clean sound quality output as possible.
Does such a thing as a freeware system EQ application exist?  If not, I guess I can come off $15 to $25 and buy a shareware EQ, but it better be really freakin' good if I have to pay for it!
  • fragtal
While I was reading the responses in this thread I came to exactly the same idea as ScorLibran has had.
As I'm using some desktop speakers that really don't have a flat frequency response and windows sound sound not like I want them to sound.
I love the moderators.
  • deaf
My favorite volume control, has no EQ but it is great to mute the sound quickly when needed. Check out Slava Glory's Volumetray. The link while editing does not look, but here it is:
Glorysoft
I have also purchased izotope ozone to do a parametric EQ in addition to Soundblaster's EQ.
I do correct for the bass weaknes of HD580 with the SB EQ and I correct for loudness with izotope ozone. Then I am happy.
  • music_man_mpc
  • Members (Donating)
I would hardly call a Live! 5.1 an expensive card.  Its cheap and old now (maybe not as cheap and as old as the PCI 128, but none the less).
  • rojmiller
A standalone freeware equalizer is RTEQ, available from:
http://members.aon.at/grxpage/index.htm
RTEQ Home
btw-  I have never been able to get RTEQ to work as it should.
  • CSMR
How about this solution:
Install ASIO4ALL driver and Plogue Bidule (or Console Sound Modular Studio).
Direct Windows sound to ASIO4ALL driver in windows control panel.
Send ASIO4ALL output via ASIO to Bidule.
Apply a vst effect (for example the equalization you want) in Bidule and send via ASIO to sound card ASIO driver.
I haven't used any of this software so can't guarantee it will work. If it does it will be a very flexible solution.
  • Last Edit: 25 September, 2008, 12:03:36 AM by CSMR
