Topic: Convert audio to video file (Read 1854 times) previous topic - next topic
I am trying to convert some flac files from 7digital into mp4 files for my Youtube channel.  There was a web site that worked great and is now adware.  I am mucking with something called Videoproc and it is not working.  I don't need a high def image.  I could download Adobe Premier, but it doesn't look like it would help.  Any suggestions?  I use the cover art for the image.
Neither Premier no Pinnacle recognize 24 bit audio files.
Daniel L Newhouse
Re: Convert audio to video file
You can use ffmpeg.
https://superuser.com/questions/1041816/combine-one-image-one-audio-file-to-make-one-video-using-ffmpeg
You can upload mkv to youtube. This way you don't need to additionally re-encode audio.
This command will copy original audio and do automatic scaling and padding to 1280x720, keeping aspect ratio of picture. It is needed because not all resolutions are accepted by x264.
ffmpeg -r 1 -loop 1 -i "image.png" -i "audio.flac" -c:a copy -c:v libx264 -r 1 -vf "scale=iw*max(1\,sar)*min(1280/(iw*max(1\,sar))\,720/ih/min(1\,sar)):ih/min(1\,sar)*min(1280/(iw*max(1\,sar))\,720/ih/min(1\,sar)):flags=lanczos, pad=1280:720:(1280-iw*min(1280/iw\,720/ih))/2:(720-ih*min(1280/iw\,720/ih))/2" -shortest "output.mkv"
I get a file that is usable in Winamp, but not Youtube.
Daniel L Newhouse
I have no problem uploading mkv file generated with this command from png image and 24/44.1 FLAC to youtube. It uploads and plays in browser as expected.
If you're on Linux
#! /bin/bash
test -z "$2" && echo "I need two input files. The first one must be a picture!" && exit 1
ffmpeg -loop 1 -i "$1" -i "$2" -acodec copy -c:v libx264 -preset veryslow -x264-params keyint=1000 -qp 0 -vf fps=10 -pix_fmt yuv420p -shortest out.mkv
I wrote this script back in 2016 for the exact same purpose. If your PC has fewer than 8 cores or it's old, you may want to replace the preset with something lighter, e.g. medium or even fast.
The image preferably should be exactly 1920x1080.
I got clideo.com to work for a couple of tracks.  Then it went dead on me.
Daniel L Newhouse
freeconvert.com does the conversion without a separate cover art assignment.
Daniel L Newhouse
Maybe covert the FLAC to WAV and than it should work with Adobe Premiere, if you cut your video with Premiere anyway.
Based on the powerful FFmpeg library, OpenShot can read and write most video and image formats. -
- https://www.openshot.org/features/
I've been (slowly) working on a bash script that takes cover.png as background and adds waveform and some moving head over it, example:
https://www.youtube.com/watch?v=iMeYtMcmjug
