Topic: Identify Songs in File Online (Read 44315 times) previous topic - next topic
Is there a plugin in foobar2000 that identifies the song and author of an mp3 file cut in turn from a single mp3 track that contains several different untagged tracks?
I use this online service:
https://www.aha-music.com/identify-songs-music-recognition-online
extremely accurate, but limited to the recognition of 10 traces per day.
This is useful for unique tracks found in services like mixcloud, soundcloud etc.
Re: Identify Songs in File Online
You could try using fpcalc.exe to generate an AcoustID Audio Fingerprint which is then checked against a database;  an easy way to do this is by using MusicBrainz Picard's "Scan" option on the file, which uses its included fpcalc.exe to return any results found from its huge music database.
There is a foo_musicbrainz plugin but I believe it deals only with tagging options.
Thank you.
I understood how it worked, even if the result was disappointing out of 5 tracks I only found one.
