Topic: V2 & Android control app.  (Read 1357 times) previous topic - next topic
I installed the latest version of Foobar 2000, but now I can't get Foobar2000 Controller Pro to work. I have been using that for many years.
Is it a V 2 thing?
Re: V2 & Android control app.
Supported: x86 32-bit, x86 64-bit.
Download and install
foo_httpcontrol_0_97_28.fb2k-component
https://bitbucket.org/oblikoamorale/foo_httpcontrol/downloads/
Setting is the same as before.
Standard installation
- \AppData\Roaming\foobar2000-v2\foo_httpcontrol_data\foobar2000controller
Portable installation
- profile\foo_httpcontrol_data\foobar2000controller
SHURE SRH1840, SENNHEISER HD660S, Beyerdynamic DT 1990 PRO, HIFIMAN HE5se, Ultrasone Performance 880, AKG K712 PRO, SONY MDR-1AM2, Bowers & Wilkins P7 Mobile Hi-Fi, Bose QuietComfort 45, SONY WH-1000XM3 (made a Upgrade/Balanced Cable by myself) Shall I write more?
foo_httpcontrol_data.zip
https://mega.nz/file/hX1UEYqb#N_KnYobKAQ3NuWgAEUy7PI8CGISLphWRKgFS0I6oL7k
-foo_httpcontrol_data
--default_1_0
--ajquery
--foobar2000controller
foobar2000 controller
http://foobar2000controller.blogspot.com/
foobar2000 controller PRO - Google play
https://play.google.com/store/apps/details?id=com.cav.foobar2000controllerpro
UPnP MediaRenderer Output
https://www.foobar2000.org/components/view/foo_out_upnp
BubbleUPnP for DLNA/Chromecast - Google play
https://play.google.com/store/apps/details?id=com.bubblesoft.android.bubbleupnp
Start:
foobar2000 v2.0 32bit 64bit > Output: UPnP: BubbleUPnP (P00A)
> Now you can listen to your foobar2000 library and controll it from foobar2000 controller.
Thanks a lot Air KEN! I thought that it was impossible to use foobar2000 as a UPnP server with 64bit version since foo_upnp is x86 only. Your solution is a great workaround that works like a charm. I think I prefer it to MinimServer.
for your information
Using BubbleUPnP for DLNA/Chromecas.
foobar's Statusbar volume icon changes.
PC Bluetooth:
foobar2000 Output: [Headphone (Bluetooth Headphone name)]
MonkeyMote 4 Foobar (foo_monkeymote): https://www.monkeymote.com/download
Android: MonkeyMote Music Remote
https://play.google.com/store/apps/details?id=com.obsidium.monkeymote
If you use BubbleUPnP for DLNA/Chromecas, it is more convenient to have License.
BubbleUPnP UPnP/DLNA License - Google play
https://play.google.com/store/apps/details?id=com.bubblesoft.android.bubbleupnp.unlocker
Thanks,
Will the previous controller client side software I installed create any problems? Should I do a clean install of Foobar 2000 v2?
Just update foo_httpcontrol.
If it is foobar2000 v2.0 64bit, a clean install is preferable.
Or how about testing in a portable installation?
OK, thanks.
I did that, and it worked, my phone now sees it and can control it.
Unfortunately, at the same time the ASIO driver (the whole reason I started messing with foobar at all, 1.69 was working fine) failed and now says "no ASIO driver found"
I installed the ASIO component last week, and it was working, changing the sample rate as needed for my RME ADI-2 DAC FS. Now I can't get it to work... I fully uninstalled foobar and reinstalled, but no help.
It is annoying when things are such a PITA to make work.
I tried 64 bit and 32 bit, neither worked...
For now, please set only foobar2000controller + foo_httpcontrol.
> OK, thanks.
Is the foobar2000controller + foo_httpcontrol problem solved?
I uninstalled it again, reinstalled the RME DACs driver, and then reinstalled. ASIO is working again, but now the controller wont work. Controller app on phone can not find specified IP address...
I will uninstall again, and install the controller component 1st, and see if it works.
I assume you can have more than 1 component installed at a time.
That didn't help. It worked the 1st time installed it as it should, but now it won't.
I'll try setting "listen on" and "start server", what do I set them to?
The laptops IP is 192.168.0.147 is that what I use?
I am thinking of going back to 1.6.9. I never tried ASIO on it, but it worked fine otherwise...
What does 2.0 do for me anyway?
Let's leave the ASIO driver issue aside.
Possible reason:
1) wrong setting (IP address ...)
2) foo_httpcontrol_data
3) blocked by firewall
Reply #1 https://hydrogenaud.io/index.php/topic,124266.msg1028366.html#msg1028366
Uncheck "Start server" and click "Appy" button (repeat).
"Start server" click → Browser sign in
         ↑ Are you ready?
Prease Screen Shot (SS): foobar Preferences > HTTP Control
foobar2000 controller (Android) → Settings
Possible reason:
         ↑ Are you ready?
OK,
Not the wrong IP, It is 192.168.0.147. I checked it multiple times.
Not sure what you mean by " foo_httpcontrol_data", but I didn't need to do anything other than install "foo_httpcontrol_0_97_28.fb2k-component" the 1st time and it worked.
I haven't touched the firewall at all, but I double checked and Foobar is added as an exception to the firewall.
foo_httpcontrol_data: tenplate and setting data
Reply #2 https://hydrogenaud.io/index.php/topic,124266.msg1028371.html#msg1028371
foobar2000  v2.0 32bit 64bit (Standard installation)
Setting folder path has changed so you need to put it in yourself
foobar menu > Shift key + menu File > Browse configuration folder
\AppData\Roaming\foobar2000-v2\ ← put "foo_httpcontrol_data" in the opened folder
              ↑ Are you ready?
(language is japanese)
Thank you very much.
It works!
That worked for the controller, now I get this error...
              ↑ Are you ready?
Thanks, that worked!
Everything is working now, controller and ASIO!  Thank you again.
EDIT: Figured out last glitch and deleted it from this post. My DAC was powered off.... ** Sheepish grin **
