Topic: Help please! Organizing massive amounts of music with file operation (Read 701 times) previous topic - next topic
I need to organize thousands of loose release into folders based on publisher/label.
They are currently in folders where I use this patter to sort them all into one place:
[ '['%catalognumber%']'] %album artist% - %album%[ '['%date%']']/%filename%
I want to keep that format, but also have them created under another hierarchy based on publisher name.
also i tried this [%publisher%/][ '['%catalognumber%']'] %album artist% - %album%[ '['%date%']']%filename%
which is almost right, but does not create release subfolders
Re: Help please! Organizing massive amounts of music with file operation
Did you mean to remove the path separator before the %filename%? If that doesn't resolve your problem then it might be worth giving an example (using an actual CD release) of how you'd like it to look.
