Topic: Time delay in audio amplifiers (Read 9192 times) previous topic - next topic
I just saw a known audiofool at another forum trying to espouse the idea that audio amplifiers can have extreme amounts of propagation delay.  He insisted that some of the higher end amps had delays on the order of 500 µS.  Further, he asserted that this needed to be taken into account when setting up bi-amplified speakers using different amplifiers.
This seems completely untenable; wouldn't an amplifier with inverting feedback and a delay of that magnitude turn into a high power oscillator at 2 KHz?
I did some research (both print literature and online) and it seems a much more reasonable value is on the order of a few nanoseconds, which of course would be completely undetectable to the ear and of no consequence to any setup or positioning of the equipment.
Do we have a new winner in the audiofool lottery?
Re: Time delay in audio amplifiers
Plausible, especially if there is any EQ or other filtering.
Take into account how? It is just a time delay, generally you don't care if it takes a few microseconds longer after you hit start for the sound to come out.
Not in a circuit with a feedback loop around it, though; he was talking about a bog-standard power amplifier, not an AV system with extra processing modules or even a DSP preprocessor section.  His contention was that the linear amplifier had an actual hundreds-of-µS propagation delay from input to output, and in a basic feedback circuit amp that would not be possible.
His thought process seemed to be that it somehow affected positioning of speakers, choice of amplifiers, etc.  That just seems bizarre.
Yes, bizarre.  A difference  between left & right could be an issue but 1/2 of a millisecond is unlikely to be heard.  It's about the time it takes the sound to move from your left eat to your right ear or being off-center by a few inches.
Or, maybe this audiophool should calculate how long it takes for the sound to get to his ears after coming-out of the speakers.
Yeah...  Computers usually have a few milliseconds of latency (or more).    I've got Beatles CDs with more than 50 years of "latency".  :D :D :D
You don't need DSP or anything like that.  Even a 40 degree phase delay at 1 KHz is over 100us.  The filtering built into the amp could conceivably add quite a lot of delay.  Not saying it will for any given amp, but having half a wavelength of delay at 1 KHz isn't unreasonable.
It sounds like he is just confused about what delays actually mean.
I dont know what he has been smoking but there is no delay that is significant. I did a real world measurement with an oscilloscope. I applied channel 1 on input and channel 2 on output. I had to drop the timebase way way down and saw nothing. Now that I think of that makes sense as most amplifiers use feedback and it would be useless if there was significant delay.There could be phase shifts but those would be a function of speaker load.
Exactly my point - a delay of (as he asserted) 500 µS would be 1/2 wavelength at 1 KHz (not 2 as I mistakenly said above) and at that frequency would provide positive feedback instead of negative at the amplifier inverting input.  That would turn the amplifier immediately into an oscillator assuming its gain was >1 at that frequency.  Typical amps have a phase shift of less than a few degrees over the audio band - again, inside the stage which contains the feedback loop.  In a basic power amplifier like the ones he was considering, that is the only stage.  Any filtering present inside the stage would have to be dominant pole compensation.  Other filters (HPF/LPF, Zobel, etc.) either before or after the feedback stage would not affect the stability and would add phase shift.  But again, that wasn't the type of amp being discussed; it was a basic power amp, one stage, with no controls.
Could be. Ordinary bandpass filters have measurable delay.   DACs have latency which is delay by a different name.
Could be. That's why careful workers measure the FR of their complex systems. Or play pink noise and listen for peaks holes. Preferably the former. Of course we're talking golden ears and measurements are anathema.
Only true if the delay is inside the feedback loop. Most amps have input and/or  output filters  that are outside the loop.
Particularly switchmode amps.
If we are talking about strictly analog circuitry, doesn't any time delay also imply a non-flat frequency response?
No. The filter that changes phase without changing gain is called an "All-Pass" filter.
You may be thinking about "Minimum Phase" filters. Their phase shift and gain are locked together by the Hilbert Transform. If you know one, you can calculate the other one from it using either the forward form of the transform, or its inverse.
No.  Wires for example have time delay but hopefully flat frequency.  Group delay dispersion (frequency dependent time delay) can imply a non-flat frequency response, but for what its worth, amplifiers do have that as well since they are hopefully filtering out ultrasound and/or DC.
I think that he mistook the power up delay with the signal delay, although this delay is important to take in consideration for the power up sequence. And a power amplifier can easily have a power up delay of 0.5 seconds or more.
So if an "All-Pass" filter produces a negative phase shift at some frequencies then this is considered to be a delay. What if it produces a positive phase shift?
Unless the OP has 150 km of transmission line in his amplifier, I don't think this is it.
Assuming a negative phase shift means a time delay, a positive phase would means that a signal output preceded input (anticausal), which is not possible in a real world filter because information flows from past to future (causality).
You can simulate filters like that though in digital systems. They aren't constrained by the Kramers Koenig relationship, which in causal systems relates changes in magnitude to changes in phase.
I came across this thread doing a search for this very issue, because I'm experiencing it and I can't understand why. So I'm bi-amping a pair of towers with an Aragon 8008 and a MonoPrice Monolith 2 channel (ATI). I was using REW to make some room mode adjustments and null's, my bi-amping is be handled by a MiniDSP flex 8. Using an acoustic reference in REW I figured out I can change nothing else besides the RCA cable that comes out of the Flex 8, thus all settings exactly the same and output switched between the input of the Monolith or the Aragon, exact same measurement and I get a 19ms delay from the acoustic reference when the Aragon is on the lows speaker input and I get 4.3ms delay when the Monolith is swapped at the Flex and speaker inputs. I can't understand it, but it is absolutely repeatable and baffling.
Did anyone come to a conclusion how or why this happens?
Thank You
