Topic: Foobar2000 balance control (Read 3326 times) previous topic - next topic
Is there a plugin for Foobar2000 which will allow the listener to adjust the balance between the left and right channels?
Re: Foobar2000 balance control
Thanks - I've installed it, but can't find any means of making it work - the layout is unchanged. Any suggestions?
@dances43
Preferences > Playback > DSP Manager > Available DSPs (Stereo Balance) → Active DSPs
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD620S, SENNHEISER HD 490 Pro Plus, beyerdynamic DT 1990 PRO, HiFiMAN Edition XS, HIFIMAN ANANDA, Bowers & Wilkins P7, FiiO FT5, FiiO FT1 Pro, 水月雨 (MOONDROP) 空鳴 - VOID, SONY WH1000XM5 (made a Upgrade/Balanced Cable by myself)
Thank you!
This is basic information which should be in the wiki.
Hello everyone,
it seems that Stereo Balance has no audible effect in my system, be it set @ 0, 50 or 100.
It doesn't react in real time, nor when i exit and Apply changes.
I can't use W Mixer because the DAC's driver skips it.
(Just to clarify, I am a musician :D)
Would anyone be able to supply some hint?
Thanks all :)
W10, Foobar 1.6.16, DAC SMSL C200 (USB), Output virtual device ASIO+DVD
It must react with delay that is equal to output buffer length (File->Preferences->Playback->Output->Buffer length).
Correct Bogozo :)
I had actually lots of other mixed issues due to an unfortunate attempt to update to 2.0. Decided I'd go for a fresh no-registry installation from scratch, which fixed most of them, including Stereo Balance's weird behaviour.
Other new issues appeared tho. Before posting and endless list of problems and boring every one on this board, I'll try and normalise things as much as I can :)
Thank your for your time
PS: Editing: it seems the plug-in's correct behaviour depends on the type of file foobar is playing... :/
