Topic: foobar2000 v2.1 bugs (Read 16822 times) previous topic - next topic
Re: foobar2000 v2.1 bugs
Nevermind, I had made an error in the advanced settings to the Properties dialog. Sorry.
Hi guys. Listening to 44.1K x 16bit, switching to new music 96K x24bit range, strange noise comes along. It only ceases after closing Foobar2000 v. 2.1 release 05.06.2023 and opening it again. Thanks.
Thanks, that was the issue pawel_na_a was trying to report. Noises with exclusive mode + smooth fader when audio stream format changes.
Edit: things should be fixed in the preview released today.
Problem with stuttering sound solved in latest preview (2023-06-07)
After updating to v2.1x64 Preview-2023-06-07 over 2.0x64 Final, I find that when using "check for updated components" I will occasionally receive the message "Could not check for updates: The specified data could not be decrypted."  The message appears immediately, without the usual "progress bar."
Usually, checking again immediately afterwards results in a normal response.  The problem is the most reproducible when newly starting 2.1, doing a "Check for new foobar2000 versions" (always works), then right after that the "Check for updated components."  I would say the frequency of the occurence that way is about 50%.  This was never observed in 2.0 Final x64.
Windows 10 x64 22H2.
The latest version of foobar2000 (v2.X) doesn't obey High Contrast settings in WIndows 10. It appears to apply to all windows (main window, options, console, ect., ect.) within the program. The old (v1.X.X) versions prior to (v2.X) don't have this problem.
What's happening is that (v2.X) is using "dark mode" colors rather than the High Contrast colors.
Hi, I get crashes on playback error when trying to play HLS radio (v2.1 preview 2023-06-07)
The radio stations are:
https://www.maxradio.ca/UHD/MaxRadio/384k/Max.m3u8 (384k AAC-LC Stereo)
https://www.maxradio.ca/UHD/MaxRadio/FLAC/Max.m3u8 (FLAC)
both work just fine in VLC
one crash report is for AAC, another for FLAC
Reply #32
@iGom, the crash logs show that foo_input_vgmstream is for some reason involved and looks like it is the cause.
Still crashes after removing foo_input_vgmstream
Reply #34
Of sorry, I didn't read the crash logs properly so I missed an important bit. You have enabled the advanced preferences option to crash when playback fails, and those streams are unrecognized by foobar2000.
Reply #35
yeah, but e.g. this station works just fine http://as-hls-ww-live.akamaized.net/pool_904/live/ww/bbc_radio_fourfm/bbc_radio_fourfm.isml/bbc_radio_fourfm-audio=96000.norewind.m3u8
Anyway, I got the previous stations to work with this component https://www.foobar2000.org/components/view/foo_input_ffmpeg, so I'll stick with this for now
Reply #36
Windows 11 22H2, foobar2000 v2.1 2023-06-07
It seems that the ReplayGain scan/playback is broken for xHE-AAC files when Windows Media Foundation is used for decoding. The values are much lower then they should be, for example I have a flac file which has track gain -6.94 dB and track peak 0.98 but the encoded file (preset 3, ~96kbps) shows track gain -1.83 dB and track peak 0.75 (the encoded files are RG re-scanned).
I also tried re-scanning the same file previously made (which has the correct RG values) and I get the incorrect (lower) values again. However when I play the file which has the correct RG, the volume is too low, but sounds OK (volume wise) when using the incorrect RG values.
Reply #37
Maybe DRC is enabled by default in WMF decoder.
Reply #38
V2.0 [x86] / W10
When foobar2000 restored down to any window size other than fully maximized, neither
- Album list filtering in the component
nor
- Properties dialog dropdown of autocomplete fields
Work correctly.
Album list sometimes won't draw and autocomplete suggestions can't be selected via down / up arrow on keyboard
Neither an audiophile, nor album snob. Why do ratings threads always have someone saying they don't believe in rating music?
Record Label Icons: 600x600 pngs appropriate for any color background:
freeimage.host/johnbuck/?list=images&sort=name_asc&page=1
Reply #40
I get inusual 0db series in meter.
Reply #41
64-Bit latest preview. Bug in Refacets filtering?
Full PATH to example file: "M:\Musik\Devices\Pop\exm\2021. 3xBACH\01. prelude 3.m4a"
This single filter is being used:
((%path% HAS \Reference\) OR (%path% HAS \Klassik\)) AND (%path% NOT HAS \VLevel\)
The tracks in above folder are included in the filter. Refacets shows a lot of folders from my Pop folder and I don't see why. Usually lists just very few tracks.
Screenshot related.
Reply #43
As Porcus said, your filter is invalid. You can fix it by changing the last part to (NOT %path% HAS \VLevel\).
Hint: you can test a filter easily with Library -> Search dialog. It will give instant feedback about syntax errors.
Reply #44
Is this under Wine perhaps? You know Peter's time is limited. There's a higher chance of getting any bug fixed if more details are given how they are triggered.
Reply #46
Thanks for the links, this has been most helpful to me.
Relevant functionality (play multi segment MP4 DASH) was missing in my code and has just been added for the next build.
For correct rendering of these stream, the application must be able to deal with:
  • Multi-segment MP4 DASH
  • FLAC in MP4 container
  • ID3 tags in MP4 container, in legit MP4 chunks, as if other MP4 tagging specs didn't exist.
It just happens that I can deal with all of this by connecting multiple pieces of own technology together. But implementing this in anything less modular is a giant pain.
Also, it's the 2020s and clowns still add ID3v2 to new file formats.
Reply #47
Greart
Great to hear that, thanks! Just in case there are also multi-channels and xHE-AAC stations if that would be helpful. kinda surprised to hear about ID3 in the MP4 container
512k AAC-LC Surround
https://www.maxradio.ca/UHD/LG73Surround/512k/LG73.m3u8
https://www.maxradio.ca/UHD/MaxRadioSurround/512k/Max.m3u8
https://www.maxradio.ca/UHD/NewWestRockSurround/512k/NewWestRock.m3u8
https://www.maxradio.ca/UHD/UptownSurround/512k/Uptown.m3u8
48k xHE-AAC Stereo
https://www.maxradio.ca/UHD/LG73/48k/LG73.m3u8
https://www.maxradio.ca/UHD/MaxRadio/48k/Max.m3u8
https://www.maxradio.ca/UHD/NewWestRock/48k/NewWestRock.m3u8
https://www.maxradio.ca/UHD/UptownRadio/48k/Uptown.m3u8
Reply #48
Not a bug per se, but the Quick Tigger dialog window (initiated through the context menu Tagging > Quick Tagger > ... > More...) doesn't use dark mode.
Reply #49
Hi, using the x86 version on windows 10 22H2 on a i7 with 16 Gig RAM
