Topic: foobar2000 v2.1 bugs (Read 16816 times) previous topic - next topic
Quote from: Notes from the developer to keep in mind:
  • Public beta versions are now called "preview" and have dates instead of numbers.
  • Preview builds for Windows will be x64 only for now. Other CPU archs will be included when nearing a stable release.
  • Visualizations don't remember size and position after exiting fullscreen mode.
  • Before the open file box pops up (shortcut CTRL + O) any highlighted items in the playlist disappear completely for a brief second before reappearing.
Re: foobar2000 v2.1 bugs
In the light theme in the "Album List" the album selection is not visible, and when there is a selection, it is dark blue, although the selection color is set to gray.
Can I make the selection everywhere gray, as specified in the settings and when switching between windows, so that the selection does not disappear?
FLAC decoder: log premature EOF, mark partially encoded files as bad even if they don't appear corrupted otherwise.
Got this error message: Screenshot. FLAC CD-Rip. Tool: reference libFLAC 1.4.2 20221022
Verify integrity:
AccurateRip verification results: The Alan Parsons Project - Gaudi
Track 1: AccurateRip Verified Confidence 200, Pressing Offset +48 [ARv2 CRC CC443B7B]
Track 2: AccurateRip Verified Confidence 200, Pressing Offset +48 [ARv2 CRC 6990E7D1]
Track 3: AccurateRip Verified Confidence 200, Pressing Offset +48 [ARv2 CRC 99B4FFDC]
Track 4: AccurateRip Verified Confidence 200, Pressing Offset +48 [ARv2 CRC 5667D935]
Track 5: AccurateRip Verified Confidence 200, Pressing Offset +48 [ARv2 CRC 39EDECCE]
Track 6: AccurateRip Verified Confidence 200, Pressing Offset +48 [ARv2 CRC 7724C252]
Track 7: AccurateRip Verified Confidence 200, Pressing Offset +48 [ARv2 CRC DE6D3427]
Track 8: AccurateRip Verified Confidence 200, Pressing Offset +48 [ARv2 CRC 7B6A899D]
Track 9: AccurateRip Verified Confidence 200, Pressing Offset +48 [ARv2 CRC CEC3E187]
Track 10: AccurateRip Verified Confidence 200, Pressing Offset +48 [ARv2 CRC CCBB9901]
Track 11: AccurateRip Verified Confidence 200, Pressing Offset +48 [ARv2 CRC A2061335]
Track 12: AccurateRip Verified Confidence 200, Pressing Offset +48 [ARv2 CRC 89BE90F0]
Track 13: AccurateRip Verified Confidence 200, Pressing Offset +48 [ARv2 CRC DFDEB284]
Track 14: AccurateRip Verified Confidence 200, Pressing Offset +48 [ARv2 CRC 74066E2F]
EDIT: Deactivated "Show error messages popups".
Latest beta (2023-05-30 x64): The two debugging options ("crash on playback error" / "crash on tag write/read error") uncheck after each launch. Got a few unexpected crashes, but because of this bug no crash report have been generated.
Report a problem with "Add Location"
inserting the radio link in the "Processing File"
Spoiler (click to show/hide)
it generates nothing.
You have to manually create an m3u file with the radio link.
Another problem with the radios.
This
 is processed and thrown into the playlist but does not play anything, while in FireFox it works.
It doesn't work for me either.
I often have stuttering sound in latest preview (2023-06-05) and must restart foobar to ged rid of this.
@pawel_na_a, you know you need to give more details unless it's a problem that is repoducible for everyone immediately without any effort. This is not one of those cases.
But I don't know what triggers that stuttering.
I can only provide list of 3rd party components:
foo_extrernal_tags
foo_skip (Skip track)
foo_input_sacd
foo_wave_minibar_mod
And this is 64 bit version, exclusive output mode.
That's a good start. Knowing the output seems like essential information when audio output stutters. The input could also be a factor, does it happen with DSD or with everything?
With everything, regardless of codec and source (file, radio)
Ok. And do you use any DSPs? And how long do you need to play to get the issue? And it really requires restarting foobar to fix? Seeking or stopping and restarting playback doesn't help?
Edit: bah with my memory. And do you have the smooth fader option on or off in output preferences?
Actice DSPs:
Skip track, skip silence and downmix channels to stereo.
Issue appears immediately after manually starting playback (but not always) Stopping and restarting playback help sometimes.
I have the smooth fader option on.
I fail to replicate the issue at least so far. Can you try if it happens in a clean portable install? Also does changing output buffer size affect it? Does adjusting the smooth fader option affect it? Have you tweaked the WASAPI overrides in advanced preferences?
It happens in a clean portable install with exclusive output and smooth fading on.
So I turned off smooth fader and so far stuttering didn't occured.
Thanks for help.
Anything on console? The exclusive mode should report buffer underruns on console. The output bug that was just fixed affected the code path where smooth fader was off, afaik smooth-fader-on mode should be unaffected by that.
Anyway, if this is a new issue it can be a bug that needs fixing. Fixing things is difficult if they can't be reproduced, so any more details you can give to replicate the problem should be helpful.
No messages on console  :(
No, it happens only with latest build.
my laptop, Windows 11 Pro Insider Preview build 25309
I can trigger the smooth fading stutter problem with 2023-06-04; 2023-06-03 seems OK so far.
The properties dialog seems to be damaged:
Properties – multiple items
The Items are listed as:
ARTIST;ALBUM ARTIST;GENRE;STYLE;PRODUCER;COMPOSER;WRITER;PERFORMER;RANK
Hi guys. Listening to 44.1K x 16bit, switching to new music 96K x24bit range, strange noise comes along. It only ceases after closing Foobar2000 v. 2.1 release 05.06.2023 and opening it again. Thanks.
