Topic: Convert .wav or .flac files to dsd64 in ffmpeg (Read 8454 times) previous topic - next topic
Is that at least possible through ffmpeg? If so, how to do it? I want to convert some of my wav files to dsd64. I looked for it in google and i didnt found anything, on each audio forum including hydrogen audio, i tried to make a .bat file with following content: -i filename.wav filename.dsf and it didnt worked.
Re: Convert .wav or .flac files to dsd64 in ffmpeg
How to do it through SoX then?
sox input.wav ouput.dsf rate -v 2822400
Thanks!!
Seems like i get an error: sox FAIL formats: no handler for file extension 'dsf'
You need to download and use the modified version, Rollin gave you the link above.
Ok, but how to install and use it? I created a .bat file with sox blank.wav blank.dsf rate -v 2822400 and it doesnt recognise sox command when i type it manually, after clicking on that .bat file console pop ups and disappears in the same time.
Ok it seemed like i downloaded wrong file, i downloaded sox-dsd-win32-MSVC.zip and everything works fine. Can someone post here a lines for dsd128 and dsd256?
DSD is snake oil.
Please remove my account from this forum.
