Re: Remastero's foo_pggb_rt, a 64 bit Foobar2000 component for resampling
Reply #8 – 2023-04-05 15:03:58
Thanks man, and your resampler sounds awesome. It's the best I've ever heard ngl, and I'm talking about just the free plugin, I wonder what the 256 bit processing could do. Best wishes to you for this project, your best clients would be the best mastering studios in the world, they'd buy your software in minutes once they hear it, at the price you expect. Hit up Gateway Mastering, Bernie Grundman Mastering, Sterling Sound Nashville and Edgewater, and so many more top notch mastering studios. I have tried all the mastering grade SRC's available everywhere, and except a direct transfer through an ADC, there's nothing that sounds so good in the digital domain. Figure this out!! Best wishes. Thanks for the kind words and the purpose of the plugin is to give easy access to good quality SRC in real-time because off-line resampling requires a lot more effort and commitment. I know there are a lot of options when it comes to SRC and this component allows one to compare for themselves what to expect from PGGB. I also see this as a proof of concept that will allow me to build an AU/VST plugin that will hopefully allow real-time resampling of streamed music. Converter isn't working now, I just updated the component from the link and tried using the converter No matter which settings I'm choosing, foobar is immediately crashing as soon as I hit convert. I enabled Optional Decoding as well, turned of all the replaygain stuff in both, preferences and converter, set almost everything in PGGB to auto and the samplerate to 1fs at 24 bit output Yet, foobar is unable to export a 24 bit wav with these preferences, could you please take a look or guide me about how to make this work? I followed the instructions on your website and tweaked with my own experience, but it's not working. I would need more information like the settings you used within PGGB-RT, the settings you chose for converting, and I assume you are on the latest 64bit version of Foobar2000? This will help me try and replicate the issue.
