Topic: Failed to load DLL Reason: Not a valid Win32 application (Read 5265 times) previous topic - next topic
I have installed foobar2000 v2.0 beta 26 and I was trying to install the Eole theme how ever I keep getting this error. I have been looking through forum posts and videos on how to fix this issue. I have installed the Microsoft Visual C++ 2010 Redistributable Package as well but it still hasn't fixed anything. Is there a way to fix this error?
Re: Failed to load DLL Reason: Not a valid Win32 application
Those errors more than likely mean you've installed the 64bit version of fb2k 2.0. You need the 32bit version.
Most components required by that theme haven't been updated so you don't have much choice if you want to use it.
Thanks it works now.
