Topic: Playlist Organizer (aka foo_plorg) replacement on Jscript Panel 3 (Read 27273 times) previous topic - next topic
I was missing too these functionalities under Foobar V2 so i tried to develop a replacement on @marc2k3 Jscript Panel 3.
I'm not a professional developer so there may be bugs, just let me know and i'll try to fix them.
The following zip contains 3 files :
main.js file which is the main panel script
panel_pl_organizer.js
pl_organizer.js which is the main code
The last 2 files are to be copied in the fb.ProfilePath + "\pl_organizer" folder
X
You need to create a JScript 3 panel, its code has to be the main.js file (copy/paste).
Jscript Panel 3 link : https://jscript-panel.github.io/docs/
Re: Playlist Organizer (aka foo_plorg) replacement on Jscript Panel 3
This is nice!
There are a few features I'd need to be able to use it more easily. I am even less of a professional developer I'd say, but I can see if I can work anything out.
Anyway:
  • Sort items within folders
  • Type to search - i.e. start typing name of playlist to jump to it
  • Multi-select is a nice-to-have. This would make it much easier to organise when you have a lot of folders
Oh, by the way, there's a stray '}' at the bottom of Main.js which causes an error when you first load it :)
thanks for the feedback new file with the add. stray corrected :
X
No worries! Thanks.
Also, the dragging to re-order is off by 1. It's counterintuitive but this works correctly:
if (this.draggedIndex < this.droppedIndex) this.droppedIndex = this.index-1 ; else this.droppedIndex = this.index;
I've also changed the yellow colour to something I preferred (a darkish purple), because I find the yellow hard to read on my screen. Maybe it'd be good to make that configurable.
yes, to be honest, i wanted to implement a color picker for the colors hence my weird yellow colors. I'll do that later :)
@etip
Could you please write the script name, version and update date?
for example:
Playlist Organizer (Jscript Panel 3)
v1.0.0
2023-03-11
Main.js
// ==PREPROCESSOR==
// @name "Playlist Manager" ← Can I change my current name?
SHURE SRH1840, SENNHEISER HD660S, Beyerdynamic DT 1990 PRO, HIFIMAN HE5se, Ultrasone Performance 880, AKG K712 PRO, SONY MDR-1AM2, Bowers & Wilkins P7 Mobile Hi-Fi, Bose QuietComfort 45, SONY WH-1000XM3 (made a Upgrade/Balanced Cable by myself) Shall I write more?
ok i will from now on.
thanks
Hi etip,
thank you very much for the new (old) foo_plorg! All of it‘s funktion work flawlessly -  no issues at all. I’m very happy with your plugin!
The only thing I would like to change, are some points of it’s design – of course this is very personal. The overall design looks a little bit „old fashioned“ with the different icons. Below I give you a little wish list what I would like to change. I would really like to do by myself but I don’t know how to realise.
1. Remove all icons.  No bold letter – or optional. Folder should differ from playlists just through their width. All playlists are indented to the right and therefore shorter.
2. Opened folder have a small arrow at their very left side. Closed folder an arrow pointing to the right (see attached pictures). No item count on folder – just plain or optional.
3. No vertical line at the beginning of each playlist.
4. Active playlist in which the current track playing is identified by a different colour which can be set by the user.
https://hydrogenaud.io/index.php?action=dlattach;sa=tmpattach;attach=post_tmp_6001_728edf665203b74b10fb3531c2c95391;topic=123820
https://hydrogenaud.io/index.php?action=dlattach;sa=tmpattach;attach=post_tmp_6001_878410b2686ac75d74544db0884172f9;topic=123820
Martin
I've done a lot of playing with the code to add some features like better navigation with the keyboard, but a drawback that will stop me being able to use the component is that you can't drag tracks into the playlists shown on the panel.
I'd love to know how one could make that work - if so, I'd be really happy with it!
Latest version (2023-03-11)
https://hydrogenaud.io/index.php/topic,123820.msg1023622.html#msg1023622
https://i.imgur.com/kk4FMBD.png Default UI
https://i.imgur.com/oOu6UBT.png Default UI - Dark Mode
Google Japanese (Japanese wiki) → English
Playlist Organizer (Playlist Manager) (JScript Panel 3 Script): by etip
Me too
@Air KEN thank you.
@DJ FRANK G. & @frogworth : i'll look into the drag & drop.
@frogworth : if you want me to integrate your code into mine let me know, that can benefit to others.
New version :
v1.1.0
19-03-2023
Changes :
Bug fixes and code optimization
Change color option for :
   - Folder name
   - Buttons
   - Playlist name
   - Selection bar
   - Background
Save configuration:
   - Auto collapse
   - Text and color preference
Album art as background
The right click menu is split in 2 :
   - Within the playlist area for contextual menus
   - Within the header area for customization menus
Got rid of the vertical lines beginning of a playlist
Let me know if you find bugs
X
I was working on this reply, and then I noticed you posted a new version, Apologies if some of what I have written no longer applies and has now been fixed.
Anyway, THANK YOU for developing this, I've been playing around with it this morning and restoring my playlist hierarchy, it's lovely to have a usable playlist manager again, and currently better than any of the alternatives.
A few requests, questions and general thoughts/feedback:
- I can't create a new folder and name it "Default", I am given an error saying it already exists, when it doesn't. Creating a folder with a different name and then renaming it to "Default" afterwards ostensibly works, however I strongly recommend against doing this because if one then renames any playlist (or even cancelling a rename operation), additional redundant folders called "Default" are created. I advise anyone to avoid calling their folders "Default" (at least for the time being.)
- Right-clicking an AutoPlaylist and selecting "AutoPlaylist...", I expect the AutoPlaylist configuration/pattern to open, but nothing at all seems to happen? Is this feature simply broken?
- It doesn't seem possible to drag a playlist from one folder directly to another, need to drag a playlist out of a folder first, before moving it to another.
- I'd like to specify my own font, for consistency with the rest of my layout (I use Tahoma.)
- Is it possible to add a scrollbar, to take some strain off my scrollwheel? (Ideally a Dark Theme-compliant one!)
- I prefer double-click to activate playlists. Some of my playlists are rather large, so I may not want to load them accidentally while organising playlists.
- I may be missing some external dependencies, because the symbols used for the Display Size/Numbers toggle, the scroll up/down buttons, the yellow currently playing playlist icon and the group icons are empty rectangles/not displaying correctly. Also the scroll up button is sort of buried under the help button and very hard to activate. To be honest, I don't particularly need these anyway (re: scrollbar, would be preferable.) Screenshot attached.
- As mentioned in a previous post, some simple colour configuration would be nice, or to have it observe colour settings specified elsewhere.
- I don't need to know the total # of playlists I have at the top. Some way to disable this message and the red line underneath it would be appreciated.
- Also there's quite a lot of padding/negative space on the left side of the panel. Not a big deal, but might be nice to save a bit of screen space.
- The vertical lines to the left of the playlist names may be unnecessary too, but not a big deal either.
- This may be a foo_quicksearch issue (forgive me if so), but the quicksearch playlist disappears from the group it's in and is recreated at the bottom of the tree. This also happened with plorg as of foobar 2.0...
- Where is the playlist/folder layout stored? Can it be backed up or imported? Is there any danger that it could be lost to an unexpected app or panel crash? I thought I'd ask this before I update to the newer version, too.
EDIT (one more) - I am experiencing significant lag when selecting songs in playlists. Does the song you have selected update the panel in some way?
Thanks again, great work with this.
@etip
Many Thanks.
https://i.imgur.com/QbX7FlF.png
Agree with some of your comments (like scrollbar).
Just wanted to say, this is a dependency of JScript Panel 3 in general. It's FontAwesome you need: https://github.com/FortAwesome/Font-Awesome/blob/4.x/fonts/fontawesome-webfont.ttf?raw=true
@iridescentaudio : thanks for this constructive and detailed feedback, really appreciated.
i can create folder with the name "Default" in my foobar. Does anyone else has that issue ?
It's fixed in the update i posted today
Yep, saw that, i thought it was working by design, it doesnt. I'll need to look into it.
Adding that to my list, i was planning on tackling the font topic next (it's quite a mess today).
I know Marc implemented one so i'll be able to use it but for my information, isnt it much easier to use the wheel ?
Ok, in my list of todos
yep, you had the answer from frogworth.
Let me know if this is what you were looking for in the last version.
i'll look into making it optional. I may have an issue because this is where the right click custom menu happens now.
i'm using it for the "note" to highlight the playlist which song is currently playing. i may change that.
done in the last version.
does that happen after you create a new search (in that case it cant stay in the folder as foo_quicksearch has no clue that folder exists. I think it deletes and recreates that quicksearch.
look for a "pl_organizer.txt" file, it should be in your fb.ProfilePath folder (use : console.log(fb.ProfilePath); if you want to know where it is).
yes, but it doesnt make sense so i'll post a new version to fix this later.
Great, thank you for your answers etip (and frogworth), much appreciated. Yeah, the new version fixed a bunch of things, already much better.
I have a lot of playlists (132 apparently!) so it takes me four scrolls of the scrollwheel to get between the top and bottom of my playlists. I could get more into the habit of collapsing folders so that I don't need to scroll, I suppose, but my instinct re: plorg is to keep all of them open and use the scrollbar.
By the way, the Auto-Collapse option crashes the panel for me with this error:
JavaScript runtime error
Unable to get property 'lvl' of undefined or null reference
File: C:\Users\Dave\AppData\Roaming\foobar2000-v2\pl_organizer\pl_organizer.js
Line: 101, Col: 4
Yea, any new search will in-effect move the playlist to the bottom. There may be some way to mitigate this in the quicksearch config, I'll investigate.
New version :
v1.2.0
19-03-2023
Version changes :
Drag & Drop from other panels/playlist viewers to populate regular playlists.
Option to double or single click to open a playlist.
X
Line: 101, Col: 4
Can you please tell me what do you do to have that error ? I'd like to try to reproduce it as it seems to work for me.
thanks
New version :
v1.2.0
19-03-2023
Version changes :
Wonderful to have drag & drop working, thanks so much @etip!
I've attached my new edited version of pl_organiser.js if you're interested.
The changes are basically just for keyboard navigation. I've added:
  • Home and End to easily jump to top and bottom of the list
  • PgUp and PgDn to go page by page
  • Left and Right - if focused on folder, close or open; if on a playlist within a folder, left jumps focus to the containing folder
  • Enter to select a playlist
Any other changes I'd made thus far were cosmetic and are basically resolved by your colour selection :)
Warning: In this version I've also disabled the Delete key, as I find it too dangerous.
If you're willing, I'd like an option to enable or disable this functionality.
@frogworth
good job!
@etip BTW, regarding:
For me, I have such a large number of playlists that using the scrollwheel is quite awkward. Grabbing a scrollbar gives me finer control, in my experience.
I've mitigated this by adding the additional keyboard navigation, but would still like a scrollbar too.
Oh, and the other thing a scrollbar does is give you a visual representation of where you are relative to the entire content of the panel.
Thank you, if you dont mind, i'll implement these navigation options so that we'll have one main script.
I'd really appreciate that - I don't want to be forked anyway!
VERY minor thing but I've added "Configure..." back (in the top context menu) here, so that one can alter Main.js without too much bother (it also allows for updating the panel when editing the other .js files).
