Topic: Unsupported stream format: 96000 Hz / 16-bit / 2 channels (0x3) (Read 2001 times) previous topic - next topic
Hello!
I've got this message: Unrecoverable playback error: Unsupported stream format: 96000 Hz / 16-bit / 2 channels (0x3)
The foo_input_sacd and foo_dsd_processor is installed.
Can anybody help me?
(foobar2000 v1.6.16)
Best regards,
Egyed Serf
Re: Unsupported stream format: 96000 Hz / 16-bit / 2 channels (0x3)
What exactly are you trying to play (file type, stream, etc.) that is giving you this error?
What Output device have you selected for playback?
Thanks for quick reaction!
I want ti play a FLAC file: Argent - All Together Now (1972)(US)[LP][24-96][FLAC]
This is a downloaded Hi-Res file digitalized from analog LP.
The output device is essential here. Foobar2000 can use exclusive mode, bypassing the Windows mixer - but if your device cannot handle the format, you will get errors. (That is what such an audio mixer takes care of ...)
nemevilagbol:  OK, but you didn't reply to what output device you had selected for playback.  I use the default Wasapi Exclusive output to my default audio device:  Speakers/Headphones (Realtek Audio) [exclusive].  Windows 10 22H2 x64.
I don't own any 24bit/96kHz FLACs, but the samples on the site here play just fine on my Foobar 1.6.16 after downloading; do they for you?:  https://anadyomene-records.com/download.htm
Ah so!
In Foobar chosed Speakers/Headphones (Realtek Audio) [exclusive] and it work!
Too bad it cannot play with my SB X-Fi Go Pro USB sound stick.
But the problem solved, thank you!
Thank you too!
The output device is really mandatory. I missed that.
Ah so!
According to the specs on the Creative wesbite for that stick, it only supports "Up to 24-bit / 44.1 kHz."
You should be able to use it though if you create a selectable DSP profile for it in Foobar that just adds a resampler to change the output sample rate to 44.1kHz. for all source input rates.
Wow!
You are magnificent!  You made my day!
Works with SB, everything all right!
Thx!
