Topic: Is there a value like %artist:1% when using foo_scrobble? (Read 1007 times) previous topic - next topic
I encountered the innocuous but uncomfortable problems seen in the picture when using foo_scrobble.
When I use %artist% in the Artist field, if a song has more than one artist, the artist's name that appears on last.fm will be a new artist separated by a comma.
I checked the relevant last.fm documents and community forums, and there is no good solution to the problem that there are multiple singers in a song.
I don't want to change the Artist field of the music tag, but I also don't want to see uncomfortable new artists made up of multiple artists on last.fm.
So, I wonder if there is a value similar to %artist:1% that can specify an artist, or is there a similar value provided by foo_scrobble?
English is not my mother tongue. I'm sorry if the expression is wrong.
Re: Is there a value like %artist:1% when using foo_scrobble?
@marc2k3
Sorry, I installed the relevant components, which seems to solve the problem, but I don't know how to write code.
If you replace the
[%artist%]
with
[$meta(artist,0)]
- do you then get what you want?
If you replace the
[%artist%]
with
[$meta(artist,0)]
@Porcus [$meta(artist,0)] is OK!!! Thanks! I've only tried [%$meta(artist,0)%], but it doesn't work.
