Topic: FLAC-git Releases (Code Base v1.4.x) (Read 49699 times) previous topic - next topic
charlieds, rennie and 3 Guests are viewing this topic.
Re: FLAC-git Releases (Code Base v1.4.x)
Reply #151
I'll post some builds...
FLAC git-a7d69df6 2024-10-28
- Windows 32-bit & 64-bit - Static binaries built with GCC 12.2.0 (MinGW)  -  [ZIP File]
- Linux amd64 & i686 - Static binaries built with GCC 14.1.0 / LIBC 2.29+  -  [TGZ File]
Can you try something like this for the latest flac version?
https://hydrogenaud.io/index.php/topic,123234.msg1018713.html#msg1018713
I would really like a new binary that is as fast or faster than this one
For the 64-bit compiles, I included a generic version and a version built with no asm optimizations that will speed up encoding for 16-bit files on AVX2 capable processors.  Other than that, performance advantages come down to the compiler/flags used.
For multithreading, use the -j option
Reply #152
Is there a guide someone can link to that can help explain to the noobs here (me included) in the simplest terms possible, exactly how to go from GitHub to a working executable much like the ones many of you have provided here?
I've added a task to github to provide automated builds after every change to the code. It is not too obvious where to get them, so I'll explain.
Go to https://github.com/xiph/flac/actions/workflows/msys2.yml?query=branch%3Amaster You'll see a bunch of tasks there, click on the topmost one with a green check mark in front of it, to get the newest one that is finished. On the next page, look for a box with the title Artifacts and download the flac-win64-static zip file. The zip file contains the latest win64 GCC builds, and the newest documentation.
@Porcus: through there, the changes discussed in https://github.com/xiph/flac/issues/699 (providing html docs for windows builds) are finally available for review  :))
Reply #153
Seriously awesome! Thank you for all your work on this KTF, you rule 🙏
Reply #154
Oof, I should have had the brain capacity to contribute more. Thanks for keeping up.
Reply #156
Would it be possible to add the Code Base Number to the ID of newer builds?
I think it would better to identify the used FLAC git version by "reference libFLAC 1.4.3 git-5152c6c 20241030" OR "reference libFLAC 1.4.3 (git-5152c6c) 20241030" OR "reference libFLAC 1.4.3 20241030 git-5152c6c" OR "reference libFLAC 1.4.3 20241030 (git-5152c6c)" for example.
Especially the last two proposed identifiers would be as similar as possible to the ID of the latest official release (which is "reference libFLAC 1.4.3 20230623").
