Topic: [v2] foo_loop (Read 4222 times) previous topic - next topic
[v2] foo_loop
32bit/64bit foo_seek 1.0 (renamed to foo_loop)
Function: Loop
Main Menu commands:
  • Playback/Loop start point
  • Playback/Loop end point
  • Playback/Enable loop (toggle)
How does it work:
Enable loop and play a track. Optional: Seek to a position in track. Press Loop start point and let the track play some time, press Loop end point: Loop.
Re: [v2] foo_seek
Component renamed: now foo_loop
Please deinstall former foo_seek.
Re: [v2] foo_loop alias foo_seek
32bit/64bit foo_loop 1.1
Tipp: Bind Keyboard Shortcuts to the commands .
Re: [v2] foo_loop
This seems like it'd be useful to make it so you can play BGM from a video game's soundtrack endlessly like how the video game itself does it. Thanks for this!
Re: [v2] foo_loop
Hi. I can't get it to work. Do I rightclick a track and look at the utility section? I  don't know how to enable the loop.
Re: [v2] foo_loop
@FartMasterExtreme
Loop
https://www.foobar2000.org/components/view/foo_loop
Menu > Loop < check
Menu > Loop start playback time
Menu > Loop end playback time
It is convenient to register with "Keyboard Shortcuts"
Preferences > Keyboard Shortcuts
Preview (foo_preview) Loop: https://www.foobar2000.org/components/view/foo_preview
Preferences > Advanced > Playback > Preview > Loop < check
foobar Restart (Shift + Menu File > Restart).
Menu > Playback > Preview
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD620S, SENNHEISER HD 490 Pro Plus, beyerdynamic DT 1990 PRO, HiFiMAN Edition XS, Bowers & Wilkins P7, FiiO FT5, 水月雨 (MOONDROP) 空鳴 - VOID, Nakamichi Elite FIVE ANC, SONY WH1000XM5 (made a Upgrade/Balanced Cable by myself)
Re: [v2] foo_loop
oops excuse me
Menu > Playback > Loop < check
Menu > Playback > Loop start playback time
Menu > Playback > Loop end playback time
Re: [v2] foo_loop
Thanks for creating this component! Just want to report a bug:
When I do NOT play the clip in its normal speed (say, in 80% speed), the loop end time is off.
p.s I use foo_dsp_effect.fb2k-component to control the playback speed, see screenshot:
https://postimg.cc/r0XgS7mq
When PB Rate is 0% (meaning normal speed), the loop end time is fine. But when PB Rate is anything other than 0%, the loop end time is off.
Re: [v2] foo_loop
Can this support LOOPSTART, LOOPEND, and/or LOOPLENGTH meta fields (sometimes they have an underscore between the words)? Those are commonly used for game soundtracks and is supported by vgmstream. It doesn't loop like it's even supported in foobar, but this is also the only loop plugin that's still being updated every so often so I thought I'd ask.
Re: [v2] foo_loop
Any way to highlight the seekbar (or waveform minibar) with the segment that's been selected to loop?
Also, if I seek inside the looped portion of the track, it does not loop when the end is reached.
