Topic: [fb2k v2] Playlist Fix (Read 6954 times) previous topic - next topic
Re: [fb2k v2] Playlist Fix
^ The internet archive has the original documentation ...
Preferences > Tools > Playlist Fix - The default matching pattern has worked fine for me but you can change it here if you need to get really specific.
Switch to playlist with dead items > File > Playlist Fix >
'Check active playlist' (this provides a report without changing anything)
'Fix active playlist' (replaces dead items with matching tracks from library)
Works like a charm!
Big thanks to @marc2k3
Thank you for this component, it is very useful. I've been using it for a while and it has always worked well.
I've just moved some folders, and it allowed me to retrieve two large playlists (2000 and 3000 items) very easily.
