Creating an ad hoc cache on JSON brings back the processing time to 2-3 secs. I know JSP has been updated to improve the situation, but that's just a patch to a design problem.
There you have it - it's still possible to deliver acceptable performance using new batch info query methods that I provided, without caching all the info all the time. If I give up right away and cache everything like old foobar2000 did, nobody will use these.
Providing zero cost access to all info was the design problem, made everyone abuse it, even my old code hammered metadb with multiple queries per processed track.
Before, foobar2000 startup was slow due to huge library being loaded regardless of user interface in use.
Now, if your user interface doesn't block waiting for data, startup is instant. And this is bad design according to you, right?
Not sure what you understood of my tests, but it's the opposite.
I had to cache the ENTIRE library tags on JSON to get back acceptable performance. I'm not talking about logical and sane coding practices of caching things which are gonna be reused, but caching all tags of all the library (or at least those which are gonna be used).
And since tag caching is slow on JS, due to the new fb v2 methods, then it's done once and done. When path changes, it gets rebuilt.
'use strict';
//06/12/22
include('callbacks_xxx.js');
include('helpers_xxx.js');
include('helpers_xxx_file.js');
include('helpers_xxx_crc.js');
if (!isFoobarV2) {console.log('Tags Cache is being used on foobar <2.0. This is not recommended.');}
// Tags cache
// Tag retrieval is too slow when retrieving tags on Foobar 2.0+
const tagsCache = {
files: {}, // one per tag
folder: fb.ProfilePath + 'js_data\\tagsCache\\',
cache: new Map(), // [ID, [Value, ...], ...], where ID = handle.RawPath + handle.SubSong
filesCRC: {},
currCRC: {},
toStr: {},
updateFromhook: false,
enabled: false,
listeners: []
_createFolder(tagsCache.folder);
_save(tagsCache.folder + '_XXX-SCRIPTS_CACHE_FILES', null); // Add info files
tagsCache.cacheTags = function (tagNames, iSteps, iDelay, libItems = fb.GetLibraryItems().Convert(), bForce = false) {
if (!isArray(libItems) || !libItems.length) {return null;}
return new Promise((resolve) => {
let items = [];
// Filter only items not cached before
tagNames.forEach((tag) => {
if (bForce) {
if (!this.cache.has(tag)){this.cache.set(tag, new Map());}
items = libItems;
} else {
if (this.cache.has(tag)){
const tagCache = this.cache.get(tag);
libItems.forEach((item) => {
if (!tagCache.has(item.RawPath + ',' + item.SubSong)) {items.push(item);}
} else {
items = libItems;
const count = items.length;
const total = Math.ceil(count / iSteps);
const promises = [];
const tf = tagNames.map((tag) => {return fb.TitleFormat(tag);})
if (!count) {promises.push('done');}
else {
let prevProgress = -1;
for (let i = 1; i <= total; i++) {
promises.push(new Promise((resolve) => {
setTimeout(() => {
tagNames.forEach((tag, j) => {
const tagCache = this.cache.has(tag) ? this.cache.get(tag) : null;
if (tagCache && tagCache.size !== count) {
const iItems = new FbMetadbHandleList(items.slice((i - 1) * iSteps, i === total ? count : i * iSteps));
const newValues = tf[j].EvalWithMetadbs(iItems);
newValues.forEach((newVal, h) => {
const item = iItems[h];
tagCache.set(item.RawPath + ',' + item.SubSong, newVal.split(', '));
const progress = Math.round(i / total * 100);
if (progress % 10 === 0 && progress > prevProgress) {prevProgress = progress; console.log('Caching tags ' + progress + '%.');}
resolve('done');
}, iDelay * i);
Promise.all(promises).then(() => {
console.log('cacheTags: got ' + JSON.stringify(tagNames) + ' tags from ' + count + ' items.')
this.updateCacheCRC(tag);
resolve(this.cache);
}, (error) => {new Error(error);});
tagsCache.getTags = function (tagNames, libItems, bFillWithTF = true) {
const tags = Object.fromEntries(tagNames.map((tag) => {return [tag, []];}))
const tf = bFillWithTF ? tagNames.map((tag) => {return fb.TitleFormat(tag);}) : null;
tagNames.forEach((tag, i) => {
if (tag.toLowerCase() === 'skip') {return;}
let bUpdate = false;
if (this.cache.has(tag)) {
const id = item.RawPath + ',' + item.SubSong;
const bCached = tagCache.has(id);
const newVal = bCached ? tagCache.get(id) : (bFillWithTF ? tf[i].EvalWithMetadb(item).split(', ') : null);
if (!bCached) {tagCache.set(id, newVal); bUpdate = true;}
tags[tag].push(newVal);
} else if (bFillWithTF) {
const newVal = tf[i].EvalWithMetadb(item).split(', ');
bUpdate = true;
if (bUpdate) {
return tags;
tagsCache.clear = function (tagNames) {
if (this.cache.has(tag)) {this.cache.delete(tag);}
tagsCache.deleteTags = function (tagNames, libItems) {
if (tagCache.has(id)) {tagCache.delete(id);}
tagsCache.load = function (folder = this.folder) {
this.enable();
if (!_isFolder(folder)) {return;}
const files = getFiles(folder, new Set(['.json']));
files.forEach((filePath) => {
const fileName = utils.SplitFilePath(filePath).slice(1).join();
const file = _open(filePath, utf8)
const obj = _jsonParse(file);
if (obj) {
const tag = obj.tag;
const entries = obj.entries;
if (!this.cache.has(tag)) {this.cache.set(tag, new Map(entries));}
else {
entries.forEach((pair) => {tagCache.set(pair[0], pair[1]);});
this.filesCRC[fileName] = this.currCRC[fileName] = crc32(file);
this.toStr[fileName] = file;
this.files[fileName] = filePath;
resolve('done');
console.log('Tags Cache loaded.');
tagsCache.unload = function () {
[...this.cache.keys()].forEach((tag) => {
this.cache.get(tag).clear();
this.cache.clear();
this.files = this.filesCRC = this.currCRC = this.toStr = {};
this.enabled = false;
this.listeners.forEach((listener) => {removeEventListener(listener.event, null, listener.id);});
this.listeners = [];
tagsCache.enable = function () {
this.enabled = true;
this.listeners = [
// Auto-update cache
addEventListener('on_library_items_added', (handleList) => {
if (!this.enabled) {return;}
const keys = [...this.cache.keys()];
if (keys.length) {
this.cacheTags(keys, iStepsLibrary, iDelayLibrary, handleList.Convert(), true);
addEventListener('on_metadb_changed', (handleList, fromHook) => {
if (!this.updateFromhook && fromHook) {return;}
if (keys.length) {
addEventListener('on_library_items_removed', (handleList) => {
if (keys.length) {
this.deleteTags(keys, handleList.Convert());
addEventListener('on_script_unload', () => {
this.save();
tagsCache.disable = function () {
tagsCache.save = function (folder = this.folder) {
for (let fileName in this.currCRC) {
if (this.filesCRC[fileName] !== this.currCRC[fileName]) {
if (!this.files.hasOwnProperty(fileName)) {this.files[fileName] = folder + fileName + '.json';}
_deleteFile(this.files[fileName], true);
_save(this.files[fileName], this.toStr[fileName]);
tagsCache.updateCacheCRC = function (tag) {
const key = _asciify(tag);
this.toStr[key] = JSON.stringify({tag, entries: tagCache}, MapReplacer, '\t');
this.currCRC[key] = crc32(this.toStr[key]);
Get your point Peter, but you are not getting mine.
If you have a process which requires ALL genre tags on library, there is no way caching on demand solves anything. First call will take 10 seconds no matter what you do, because now it's not free. Yep you can cache it for the second time.
But what about requiring ALL genre tags from just part of the library? You have to create a cache linked somehow to UUIDs per track. Or something more complex:
And to work on first call, it must be done on init, once. What I did ok, but then... this is just full library tag caching, the thing you removed XD
I'm just saying all these should be added back built-in, for configurable tags. Let the user choose if they want to have 10 seconds startup more to have free tag access aftewards or not.
