Topic: FLAC v1.4.x Performance Tests (Read 84341 times) previous topic - next topic
Re: FLAC v1.4.x Performance Tests
Reply #175
Upper: fast-math-noasm-manyflags-haswell-git
Lower: Case GCC 12.2.0
1579150352 bytes PCM size
-8 -b16384 -A "subdivide_tukey(3/2e-1);welch;hann;flattop"
Total encoding time: 0:41.172, 38.18x realtime
769068252 bytes
Total encoding time: 0:36.953, 42.54x realtime
769068236 bytes
Combining cheap windows sometimes can produce good results.
Reply #176
hann is tukey(1) - the tukey windowing is a rectangle with cosine tapering, and when the "rectangle" hits zero width there is only the cosine left: https://en.wikipedia.org/wiki/List_of_window_functions#Tukey_window
So again you got "two very differently tapered tukeys".
flattop is a weirdo, it is even negative somewhere, but at HA fifteen years ago, it would do well in combination with tukey, so it is an obvious "try this if you want another".
For high resolution - and I got a bit of my testing material from 2L too! - I recall that a gauss window sometimes did "surprisingly" well. That is, surprise compared to it being of very little value for CDDA.
Note, welch = parabola and gauss = exp(parabola).
Reply #177
Tested a loud 24-96 album and the performance hit is pretty hefty indeed. -8 -p single file.
Case 1.4.1
26.71x realtime
1.4.1 manyflags -Ofast
27.63x realtime
21.36x realtime
Reply #178
Oh, 96/24 ... Attached: a few seconds of 96/24, squeezed down to < 2 MB.
Not at all randomly selected: 1.4.1's double precision makes savings like 17 percent at -7, that is YUGE. (But, it is not so that I cherry-picked the best-looking few seconds in the track. Though I did avoid the most dense part.)
* Compared to CDDA, it is easier to beat -p by stacking up with -A [functions]. For the full track, I could beat -p at half the encoding time
* -b [something] can often make a difference on 96/24, but default looks good on this clip. Also the gains from -r are not jaw-dropping either.
At https://hydrogenaud.io/index.php/topic,120158.msg1003288.html#msg1003288 I used the entire EP for testing, but of course I cannot share more than a clip. Buy it :-)
Music: "Temptation", 2017 remake, by Canadian band The Tea Party (who, name-wise, suffered halfway the same fate as ISIS ...)
Known for "Moroccan roll" style hard rock, however this track is largely industrial synth. I bought the EP from https://teaparty.com/tx20 , (2.99 Canadian $ - and 1.99 in MP3 for those of you who happily let others do the lossless testing). You can listen there or on Spotify, https://open.spotify.com/album/6Q3GV4HsGwPzQ9a2TA8cg0
Reply #179
If it is unavoidable then I can still use 1.4.1 for hi-res and 1.4.2 for CDDA.
Reply #180
Flattop tends to work better when the upper spectrum is more empty. An example of DSD to flac conversion with different filtering.
X
-8 -A subdivide_tukey(3/2e-1) with and without flattop
818465962 25kHz flattop.flac
818511667 25kHz.flac (.0055842% bigger)
886963408 Multistage flattop.flac
886996117 Multistage.flac (.0036878% bigger)
Another example, the "raw DXD" file:
http://www.2l.no/hires/DXD-DSD/index.html
209196492 JGH flattop.flac
209215084 JGH no flattop.flac (.0088873% bigger)
With optimal -b the effect is even bigger.
-8 -b16384 -A subdivide_tukey(3/2e-1) with and without flattop
207277309 JGH flattop.flac
207300539 JGH no flattop.flac (.0112072% bigger)
Reply #181
The weakness of git version is 24-bit.
Upper: Case GCC 12.2.0
Lower: fast-math-noasm-manyflags-haswell-git
-8p
16/96
Total encoding time: 0:05.204, 59.04x realtime
Total encoding time: 0:04.922, 62.43x realtime
16/192
Total encoding time: 0:12.406, 24.76x realtime
Total encoding time: 0:11.859, 25.91x realtime
16/352
Total encoding time: 0:26.329, 11.67x realtime
Total encoding time: 0:25.657, 11.97x realtime
24/96
Total encoding time: 0:12.828, 23.95x realtime
Total encoding time: 0:15.469, 19.86x realtime
24/192
Total encoding time: 0:27.688, 11.09x realtime
Total encoding time: 0:34.485, 8.91x realtime
24/352
Total encoding time: 0:53.562, 5.73x realtime
Total encoding time: 1:26.813, 3.53x realtime
Reply #182
flac git-92928f28 20221017
Clang 16 vs GCC 12.  Both compiled with the same cflags/cxxflags.
Compiled with GCC 12.2.0
Copyright (C) 2000-2009  Josh Coalson, 2011-2022  Xiph.Org Foundation
flac comes with ABSOLUTELY NO WARRANTY.  This is free software, and you are
welcome to redistribute it under certain conditions.  Type `flac' for details.
the_fragile_album.wav: Verify OK, wrote 658916991 bytes, ratio=0.600
/usr/local/bin/flac -V -8 the_fragile_album.wav
Encode Time: 1:34.67
the_fragile_album.wav: Verify OK, wrote 658690092 bytes, ratio=0.600
/usr/local/bin/flac -V -8 -e the_fragile_album.wav
Encode Time: 1:56.36
the_fragile_album.wav: Verify OK, wrote 658391508 bytes, ratio=0.599
/usr/local/bin/flac -V -8 -p the_fragile_album.wav
Encode Time: 1:55.56
the_fragile_album.wav: Verify OK, wrote 658115494 bytes, ratio=0.599
/usr/local/bin/flac -V -8 -e -p the_fragile_album.wav
Encode Time: 7:12.51
the_fragile_album.wav: Verify OK, wrote 659488938 bytes, ratio=0.600
/usr/local/bin/flac -V -8 -b 2304 the_fragile_album.wav
Encode Time: 1:22.54
the_fragile_album.wav: Verify OK, wrote 659082364 bytes, ratio=0.600
/usr/local/bin/flac -V -8 -A tukey(5e-1);partial_tukey(2);punchout_tukey(3) the_fragile_album.wav
Encode Time: 1:25.99
Clang 16.0.0
Encode Time: 1:06.14
Encode Time: 1:56.12
Encode Time: 2:00.89
Encode Time: 11:54.96
the_fragile_album.wav: Verify OK, wrote 659488936 bytes, ratio=0.600
Encode Time: 0:58.16
Encode Time: 0:51.12
Reply #184
Compiling with --disable-asm-optimizations Clang slows the performance to half for 24-96 files against pure gcc.
Is --disable-asm-optimizations the right way atm.?
Reply #185
Ha! Didn't know that.
In frontah a 1.6GB flac decodes to wav in ~10 sec. with the Case and my manyflag fast-math version. I don't see a problem. You may have a better test.
flac 1.4.1 = Case GCC 12.2.0
flac git-0665053c 20221013 = fast-math-noasm-manyflags-haswell-git
8h46m48s single flac file (~3502MB) encoded with -l0 then decoded with -ts
flac 1.4.1
H:\>flac -ts H:\Image.flac
00:00:20,06
00:00:23,49
Same file encoded with -l6 then decoded with -ts
flac 1.4.1
00:00:20,61
00:00:21,39
Same file encoded with -l12 then decoded with -ts
flac 1.4.1
00:00:22,18
00:00:22,95
Same file encoded with --lax -l32 then decoded with -ts
flac 1.4.1
00:00:25,00
00:00:25,73
The timing was done using this method:
https://stackoverflow.com/a/9938411
I modified the script a bit, drag and drop a flac file into the cmd file to test in the same way I did. Even preset -5 uses -l8 so the differences should be small in most cases. Don't know it is CPU dependent or not.
Reply #188
Speed differences in decoding lower -l is real.
-l0
PS H:\> measure-command {h:\flac-case -ts image.flac | out-default}
TotalSeconds      : 20.2462909
PS H:\> measure-command {h:\flac-git -ts image.flac | out-default}
TotalSeconds      : 23.5196237
-l8
TotalSeconds      : 21.362982
TotalSeconds      : 22.1673663
Reply #189
So it seems in my test with Clang 16 vs GCC 12, Clang only seems to have the advantage with larger files being written to the storage device.  In my case, I'm using a single SSD in a ZFS pool.  I noticed encoding with the GCC compiled version, times were consistent within 1 second after multiple rounds of the same test, however, with the Clang compiled version, times seemed to vary more between rounds.  I wonder why Clang seems to do better when files are written to a disk...
Each round of test was done in order with these options:
flac -d *.flac
flac -V -8 *.wav
flac -V -8 -e *.wav
flac -V -8 -p *.wav
flac -V -8 -e -p *.wav
flac -V -8 -b 2304 *.wav
flac -V -8 -A "tukey(5e-1);partial_tukey(2);punchout_tukey(3)" *.wav
Nine Inch Nails - The Fragile (single file for whole album)
GCC 12.2.0 - R/W to disk
Decode Time: 0:37.55
Encode Time: 1:34.83
Encode Time: 1:56.33
Encode Time: 1:53.33
Encode Time: 7:09.77
Encode Time: 1:30.12
Encode Time: 1:24.01
Clang 16.0.0 - R/W to disk
Decode Time: 0:36.79
Encode Time: 1:19.53
Encode Time: 2:28.14
Encode Time: 2:26.93
Encode Time: 11:54.74
Encode Time: 1:23.08
Encode Time: 0:59.60
GCC 12.2.0 - R/W to ramdisk
Decode Time: 0:05.28
Encode Time: 0:20.43
Encode Time: 0:56.15
Encode Time: 0:53.01
Encode Time: 6:11.10
Encode Time: 0:22.19
Encode Time: 0:24.88
Clang 16.0.0 - R/W to ramdisk
Decode Time: 0:05.52
Encode Time: 0:23.80
Encode Time: 1:27.26
Encode Time: 1:29.84
Encode Time: 10:47.43
Encode Time: 0:24.70
Encode Time: 0:28.96
And because someone mentioned The Tea Party!
This test mixed the album Transmission as individual tracks and Interzone Mantras as a single file.
GCC 12.2.0 R/W to disk
Decode Time: 0:42.11
Encode Time: 1:18.81
Encode Time: 1:58.11
Encode Time: 1:52.34
Encode Time: 7:26.50
Encode Time: 1:25.81
Encode Time: 1:27.76
Clang 16.0.0 R/W to disk
Decode Time: 0:43.53
Encode Time: 1:27.22
Encode Time: 2:30.46
Encode Time: 2:35.19
Encode Time: 12:20.65
Encode Time: 1:15.82
Encode Time: 1:00.24
Decode Time: 0:05.37
Encode Time: 0:20.91
Encode Time: 0:57.80
Encode Time: 0:53.64
Encode Time: 6:24.09
Encode Time: 0:22.74
Encode Time: 0:25.49
Clang 16.0.0 - R/W ramdisk
Decode Time: 0:05.67
Encode Time: 0:23.27
Encode Time: 1:29.83
Encode Time: 1:29.42
Encode Time: 11:07.48
Encode Time: 0:25.76
Encode Time: 0:25.12
Reply #190
flac1013 = Wombat fast-math-noasm-manyflags-haswell-git
flac1021 = john33 flac-1.4.1-git-6abf272-20221021
flac141 = Case GCC 12.2.0
24-bit transcoding (96-352kHz)
PS H:\> measure-command{h:\flac1013 *.flac -fs8 -b16384 -A "subdivide_tukey(3/2e-1);welch;hann;flattop"}|select totalseconds
TotalSeconds
  60.2480702
PS H:\> measure-command{h:\flac1021 *.flac -fs8 -b16384 -A "subdivide_tukey(3/2e-1);welch;hann;flattop"}|select totalseconds
TotalSeconds
  56.8414738
PS H:\> measure-command{h:\flac141 *.flac -fs8 -b16384 -A "subdivide_tukey(3/2e-1);welch;hann;flattop"}|select totalseconds
TotalSeconds
  55.1369771
16-bit transcoding (48kHz)
PS H:\> measure-command{h:\flac1013 *.flac -fs8}|select totalseconds
TotalSeconds
   76.156825
PS H:\> measure-command{h:\flac1021 *.flac -fs8}|select totalseconds
TotalSeconds
  86.8591274
PS H:\> measure-command{h:\flac141 *.flac -fs8}|select totalseconds
TotalSeconds
  83.7913263
Decoding files encoded with -8 (16-bit 48kHz) For unknown reasons there is always a startup delay in the first, non-repeating decoding command despite using RAM disk, so both first and second runs are posted.
PS H:\> measure-command{h:\flac1013 -ts *.flac}|select totalseconds
TotalSeconds
  19.7201548
TotalSeconds
  16.9045647
PS H:\> measure-command{h:\flac1021 -ts *.flac}|select totalseconds
TotalSeconds
  20.4929391
TotalSeconds
  17.6664767
PS H:\> measure-command{h:\flac141 -ts *.flac}|select totalseconds
TotalSeconds
  19.6514963
TotalSeconds
  16.8442894
Decoding files encoded with -8 -b16384 (24-bit 96-352kHz)
TotalSeconds
   11.280577
TotalSeconds
   8.4720569
TotalSeconds
  11.5633101
TotalSeconds
   8.7760674
TotalSeconds
  11.2297442
TotalSeconds
   8.4221105
Decoding files encoded with -l0, mixed bit-depth and sample rate:
TotalSeconds
  14.9447091
TotalSeconds
  12.1270033
TotalSeconds
   13.809708
TotalSeconds
  10.9962077
TotalSeconds
  13.2682311
TotalSeconds
   10.469793
Reply #191
Seems that with the next release building without asm optimizations is good for 16bit only apps llike CUETools (besides HDCD).
Attached a current git versioin of both ways to compile.
Reply #192
TotalSeconds
  60.2480702
TotalSeconds
  56.8414738
TotalSeconds
  55.1369771
PS H:\> measure-command{h:\flac1021wombat *.flac -fs8 -b16384 -A "subdivide_tukey(3/2e-1);welch;hann;flattop"}|select totalseconds
TotalSeconds
  55.8933077
PS H:\> measure-command{h:\flac1021wombat-noasm *.flac -fs8 -b16384 -A "subdivide_tukey(3/2e-1);welch;hann;flattop"}|select totalseconds
TotalSeconds
  60.1707838
Same files in same sample rates, but 16-bit
TotalSeconds
  37.7704419
TotalSeconds
  35.4706544
Reply #193
Deathblow with -p
24/48, 8 wav files, multi-thread, -8p
Total encoding time: 1:12.704, 176.12x realtime
flac1021wombat
Total encoding time: 0:59.812, 214.08x realtime
Same files but 16/48
Total encoding time: 0:29.735, 430.62x realtime
flac1021wombat
Total encoding time: 0:29.656, 431.77x realtime
Reply #194
I tested again my AMD Ryzen 5 3600X with different builds to see if there is some encoding speed up.  8)
flac -8p
Source
Codec      :     PCM (WAV)
Duration   :     57:21:749
Sample rate:     48000 Hz
Channels   :     2
Bits per sample: 16
flac 1.4.1-win64 Xiph
wrote 425812106 bytes, ratio=0,644
Global  Time =    56.570
flac-1.4.1-win64-znver3 (Case)
wrote 425812103 bytes, ratio=0,644
Global  Time =    54.792
FLAC-1.4.1-git-6abf272-20221021 (john33)
Built on October 21, 2022, GCC 12.2.0
(Code Base : 1.4.1) (-Ofast -m64 -march=haswell)
Global  Time =    57.293
(Code Base : 1.4.1) (-Ofast -m64 -march=znver2)
Global  Time =    52.017
Reply #195
@music_1 : If you test -8, -8r8 and -8e rather than -8p, what happens?
Asking because -p brute-forces part of the process, -e a different one. Of course -8 is faster than either (and -8e is not much useful anymore!), but it is interesting to see whether the order of compiles stays the same. If not, then one makes part of the job more efficient and another a different part of the job.
Reply #196
Deathblow with -p
flac1021wombat
flac1021wombat
flac1021znver2john33
24/48
Total encoding time: 1:03.859, 200.51x realtime
16/48
Total encoding time: 0:29.985, 427.03x realtime
My i3-12100 must be a remarked Ryzen  :))
Reply #197
flac -8
wrote 426124832 bytes, ratio=0,645
Global  Time =    18.246
wrote 426124828 bytes, ratio=0,645
Global  Time =    17.863
Global  Time =    17.792
wrote 426124836 bytes, ratio=0,645
Global  Time =    17.647
flac -8r8
wrote 426124602 bytes, ratio=0,645
Global  Time =    20.921
wrote 426124598 bytes, ratio=0,645
Global  Time =    20.196
wrote 426124606 bytes, ratio=0,645
Global  Time =    20.341
Global  Time =    20.960
flac -8e
wrote 426050030 bytes, ratio=0,645
Global  Time =    51.351
wrote 426050026 bytes, ratio=0,645
Global  Time =    52.222
wrote 426050035 bytes, ratio=0,645
Global  Time =    50.218
Global  Time =    51.782
Reply #199
Thanks. Here are results with some AVX-only builds.
Case GCC 12.2.0
Total encoding time: 1:11.218, 30.19x realtime
425513472 bytes
http://www.rarewares.org/files/lossless/flac-1.4.1-x64-znver2-GCC1220.zip
Total encoding time: 1:13.328, 29.32x realtime
425513429 bytes
znver3
Total encoding time: 1:11.891, 29.91x realtime
425513429 bytes
http://www.rarewares.org/files/lossless/flac-1.4.1-x64-AVX2%20-GCC1220.zip
Total encoding time: 1:12.250, 29.76x realtime
425513472 bytes
Case Haswell
Total encoding time: 1:16.328, 28.17x realtime
425513511 bytes
It seems that the Ryzen builds have no compatibility issue with my Intel CPU.
No joke. Looks like a znver3 build would ever be better.
