Topic: FB2K's Masstagger (Read 110820 times) previous topic - next topic
FB2K's Masstagger
Update: This post is very old now and contains lots of inaccurate or outdated information.
Please read the more up to date wiki article instead.
Allrigth seems like these days the word tutorial, FAQ, whatever has been mentioned a few times once again on the forums.  Seems to be kind of a dreadful issue that resurfaces every once in a while.  And since I've been busy using FB's masstagger quite a lot lately and quite like this feature, I thought I'd try  to make a more or less newcomer friendly guide to said function.  Trying to explain the whole of FB2K probably would have been a bit much and I guess everyone knows how to hit a play button and encue a few files (well probably not everyone, but we'll put that aside for a different discussion).  So basically the only thing needed is probably a few of FB's advanced functions explained in detail.
So here is my first humble attempt at a small explanation, tutorial, FAQ, call it whatever, of one of FB's rather powerful features.  Note that this is meant to also be understandable for people who have had no contact with these features at all yet, so it might explain the obvious a few times and is probably an entirely boring read for advanced users.  So for anyone who cares to read, here is,
The Unofficial Guide to FB's Masstagger
FB's masstagger tends to be quite a convenient tool when editing the information of tags in multiple files.  I will first briefly list the options you have using it.  Basically you can choose to either use it to edit tags or to rename files from the FB2K context menu.  Here I will go into details of the first option.  Although the second option should become quite self explanatory after reading this.
Basically there are several actions you can choose from to perform.
Actions to perform:
Set value
Sets desired tag field (artist, album,custom,etc) to whatever you enter in the masstagger input window.
Add value
Adds desired tag field and sets it to whatever you enter in the masstagger input window.
Remove value
Removes desired tag field.
Remove all values
Removes all tag fields  (who would have guessed)
Copy value
Copies one tag field to another.
Guess values from filename
Guesses values from filename and lets you enter a certain fromatting pattern for it.  For example if your files are named    artist - album_title.
Enter %artist% - %album%_%title    as formatting pattern.
Format value from other fields
This is where it becomes interesting.  This option lets you enter a specific formatting pattern for any tag field you wish to edit or create.
Note that when using complex formatting patterns I would recommend to first format a temporary %temp% tag with the desired pattern and then copy that one into the value that you wish.  Afterwards you can remove the temp value.  When processing a large batch of files you could probably just do a test run on one of the files and then do the rest in one go.  Think about what you are doing beforehand though.  After all I don't want to be held responsible for messing up anyones music collection.
I will explain how to create formatting strings for different situations further down .
Remove all values except for...
Does just as it says, removes all values and lets you specify wich ones not to remove in a second field in the following pattern ie.:
%artist%;%title%;etc
Auto track number
Haven't really tried out this one in depth, guess it does kind of what it says.
Split multiple artist field
Same thing goes for this one.  Never really used it yet.
Notethat it is possible to perform several of these actions at once and in that case the order of those actions can be very important.  So removing field A before copying it to field B is probably a bad Idea and should be performed the other way around, etc.
Offtopic:  Excellent, Pizza just arrived.  This friday evening is improving.
Writing format strings for the masstager:
Well I guess the most powerful feature of FB"s masstager is the fact that it can use TAGZ format strings.  For reference to all TAGZ commands please check the titleformatting help in your Foobar preferences.
You can see that all the following samples contain %tag% and capital variables in the form of X, Y, Z.  The idea is that you replace %tag% by what ever field value you would like to read from (ie,%artist%, %title%, etc.  .  What X,Y, Z stands for should be explained above the strings.  (Well and it obviously should also be replaced by whatever fits your needs)
I can only say once more please check the titleformatting help for reference since it explains all available tag fields and commands.  Instead of %tag% you could for example also use %_filename%, etc as input fields.
Allright before everyone gets bored with me blabbing on for to long I'll simply throw in those scripts.  Everything starts extremely simple to give a basic idea on how everything works.  After all this is basically meant for new users.
The idea is that by the end of this you can write your own little scripts easily.  Or of course simply copy and paste these into the Masstager window for further editing.  Just don't hold me responsible to what happens to your files.
Masstagger Strings:
Please make sure you rejoin scripts that have been split into multiple lines, before pasting them into the masstagger window. The reason they are split is to keep this page's formatting readable in your browser.
Returns corresponding tag field:
%tag%
Example: if artist field is blah %artist% will return blah.  Note that you can insert any character (or space) in between two tags, in front or after, so if artist is blah and title is bleh %artis%X%title% returns blahXbleh.
Trunctuates %tag% to a length of X characters:
$cut(%tag%,X)
Example: if artist field is blah $cut(%artist%,3)  returns bla
Truncuates %tag% by X characters and adds ... at the end of the cut.
$cut(%tag%,X)...
Example: if artist field is blah $cut(%artist%,3)...  returns bla...
Returns numerical value of %tag% and pads with 0s up to x characters
$num(%tag%,X)
Example: if tracknumber field is 3 $num(%tracknumber%,2)  will return 03. If 13 it will return 13.
Returns first two characters of a filename and displays as number (if present) padded with 0s up to X characters:
$num($left(%_filename%),2)
Example: if filename is 03_artist_title.mpc  will return 03.
Finds first occurence of character X in %tag% and returns everything in front of X:
$puts(spacer,$strchr(%tag%,X))
$trim($left(%tag%,$sub($get(spacer),1)))
Example: blah X bleh  or  blah X bleh X bluh    returns  blah    (ie.:  artist_album_title    ----->  title,    in case X is  _ )
NOTE:In the next few strings I have decided to make it possible to define the %tag% that should be edited and the character or string that is used to determine where to trunctuate as variables in the beginning of the string as $puts(tag,%tag%), $puts(char,X), etc.  Basically the reason I have done this is to make it simpler to edit these strings, to what you exactly want them to do at the very moment, in the rather narrow masstager input field.  That way it is possible to enter the needed tags and characters only once in the beginning of the line.  Again simply replace %tag% and X by the desired values.  Also all of these strings will trim off the trailing and leading spaces of the output (in case there are any).
$puts(char,X)$puts(tag,%tag%)$puts(spacer,$strchr($get(tag),$get(char)))
$trim($left($get(tag),$sub($get(spacer),1)))
(Note this does exactly the same as the last string mentioned above, except for the introdution of the two variables in the front, meant for easy editing)
Finds last occurence of character X in %tag% and returns everything in front of X:
$puts(char,X)$puts(tag,%tag%)$puts(spacer,$strrchr($get(tag),$get(char)))
Example: blah X bleh  returns  blah  and  blah X bleh X bluh    returns  blah X bleh
Finds first occurence of character X in %tag% field and returns everything after X:
$trim($right($get(tag),
$sub($len($get(tag)),$get(spacer))))
Example: blah X bleh    returns bleh    and blah X bleh X bluh    returns  bleh X bluh
Finds last occurence of character X in %tag% field and returns everything after X:
Example: blah X bleh    returns bleh          and    blah X bleh X bluh    returns  bluh
Finds first occurence of character X and last occurence of character Y and returns everything in between:
$puts(char1,X)$puts(char2,Y)$puts(tag,%tag%)
$puts(spacer1,$strchr($get(tag),$get(char1)))
$puts(spacer2,$strrchr($get(tag),$get(char2)))
$trim($substr($get(tag),$add($get(spacer1),1),$sub($get(spacer2),1)))
Example:  blah X bleh Y bluh    returns bleh
Note that in most cases X will probably be equal to y here.
Finds first occurence of string XYZ and returns everything in front of string XYZ:
$puts(string,XYZ)$puts(tag,%tag%)$puts(spacer,$strstr($get(tag),
$get(string)))
Example: blah XYZ bleh    returns  blah
Note that string XYZ can basically be any combination of characters or words.
Finds first occurence of string XYZ in %tag% field and returns everything after XYZ:
$puts(spacer,$strstr($get(tag),$get(string)))
$trim($right($get(tag),$sub($len($get(tag)),
$add($get(spacer),$len($get(string))))))
Example: blah XYZ bleh    returns bleh
Extracting Information from Relative File Paths:
As suggested I have included a small section on how to extract different values from their relative file paths.  To do so I will use the following example path to extract information from
...\Genre\Artist\Album[Date]\01_Title.mpc
sets title:
%_filename%        returns title as      01_Title.mpc    and
$puts(char,_)$puts(tag,%_filename%)
$trim($right($get(tag),$sub($len($get(tag)),$get(spacer))))
returns title as  Title.mpc
sets album:
$directory(%_path%,1)        returns title as      Album[Date]
$puts(char,'[')$puts(tag,$directory(%_path%,1))
returns album as      Album
NOTE that the [ is quotes as '['    ,  the reason for this is for it to be recognized as a character and not as a command syntax,  you will probably have to ommit the quotation marks for most other characters.
sets artist:
$directory(%_path%,2)        returns  artist as Artist
sets genre:
$directory(%_path%,3)          returns genre as Genre
sets tracknumber:
$num($left(%_filename%,2),2)      returns tracknumber as 01
Obviously a lot more is possible, but then this was just supposed to be a short introduction.  I would say simply copy a few of your files, and play around with it.
The Rename Files Dialog
The rename files dialog enables you to automatically rename your files according to your metadata tags in an automated way.  You will first need to select all the tracks you want to rename and then right click and select: Masstagger/rename files.
Select in the masstagger dialog wich output directory you mant to use and wether to generate subdirectories according to the / \ characters.  I will give a few examples for renaming strings below.
Examples
To rename your files to "tracknumber_title.ext (i.e. 08_The Glass Bead Game.mpc)" you will need to enter the following syntax in the Output file name format field
%tracknumber%_%title%
No need to create subdirectories in this case.
To rename your files to "/artist - album/title.ext (i.e. Thievery Corporation - Sounds of the Thievery Hi-Fi/08_The Glass Bead Game.mpc) and create the appropriate subdirectories you will need the following syntax
/%artist% - %album%/%tracknumber%_%title%
In this case make sure the "create subdirectories" checkbox is ticked.
To rename your files to "/artist/album/tracknumber_title.ext (i.e.: /Thievery Corporation/Sounds of the Thievery Hi-Fi/08_The Glass Bead Game.mpc) use the following syntax
/%artst%/%album%/%tracknumber%_%title%
In case you generally make use of "album artist" tags (or anything similar) for various albums files you can replace %artist% with
$if2(%album artist%,%artist%)
in any of the above strings.
Note
One reason why it is convenient to use the masstaggers rename files function is that this way Foobar2000's database will automatically get updated to the current changes.
Of course this only gives a general idea of what is possible and all kind of different filenaming schemes can be used for this.
And as usual, please don't hold me responsible in case this makes a mess out of any of your files
In case the renamer ever does anything unexpected, don't dispair, it is usually very easy to fix with just another renaming operation.
Well, if your still with me now I guess thats quite a good sign and at least you didn't get all to bored along the way.  Hope this is all somewhat comprehensible and can give people who are new to this a general idea on how things work.  Concerning Foobars Masstagger at least.  Any suggestions and especially critisism, corrections and add ons extremely welcome.
Oh yeah and in case you ever get bored of any of those old bad quality Kazaa files that might still be lying around on your harddisk you can
always replace %tag% by $rot13(%tag%) , mess them all up a bit and make your filenames gow all blowfish.  (allright, for all humorless people, it's a joke, PLEASE DON'T DO THIS, except of course if you are really bored with them)
Hmh lots of blehs and blahs, guess I should have used something a bit more creative .  Otherwise I might as well have called this thread BlahBlah.
In case you find any ingenious strings or even better simple ones, I suggest everyone can simply post them in this thread.
EDIT:  Damn this page turned out really wide,  Anything I can do about that.  (Well, except posting annoyingly long posts like this one  )
EDIT2:  Allright, this works better now.  Thanks Jan
EDIT3:  Included relative file paths section
EDIT4: Removed strange formatting again. Thanks to SamK for taking most of the workload off me.
FB2K's Masstagger
I believe you have to manually insert "new-lines" in your long one "word" strings.
edit: btw. really nice!
FB2K's Masstagger
Hmh, will have to think about this one.  Sounds like quite a task.
FB2K's Masstagger
As far as I could see only 4 lines or so are too long.
FB2K's Masstagger
Thank you picmixer. This is much help for a dingbat like me.
FB2K's Masstagger
Very nice,good work!
I suggest you should add an example to explain how to get values from the path(e.g. \Genre\Artist\Album[Date]\01_Title.mpc) by using "Format value from other fields".
I think that trick is very useful.
FB2K's Masstagger
Thanks for the feedback everyone.
@/\/irana
Included "extract info from relative file paths section,  hope it is what you had in mind.
FB2K's Masstagger
It's "unoffical"
FB2K's Masstagger
It's "unoffical"
Already had a bad feeling about this.  Anyway it's corrected in the post now, I don't think I can change the topic title.  Not that important though.
FB2K's Masstagger
Thanks for this.
FB2K's Masstagger
Updated this slighly today.
Basically added a small section on renaming files.
FB2K's Masstagger
Very useful guide, too bad I found it after I spent hours figuring it out myself
One thing though, some of the strings get cut off when I paste them into the formatting pattern box.  I'm using the latest verson of foobar(.8.2) am I just missing something or do they get cut off for anyone else?
FB2K's Masstagger
Yes, I had to split  a few of the scripts into two lines to make sure this page does not become unnaturally wide.  You will have to rejoin them before pasting them into the Masstagger.
See the first three posts of this thread, where JanS told me the trick
FB2K's Masstagger
Picmixer: Please don't take anything I say as a complaint or a put-down of the work you did.  I really appreciate it, but I thought that perhaps you might like a few comments from the viewpoint of someone that doesn't know anything about masstagger, but does know something about training and user communications -- I used to be an editor at a computer magazine.
You say:
Basically you can choose to either use it to edit tags or to rename files from the FB2K context menu. Here I will go into details of the second option.
When you say that it sounds to me like "the second option" means "to rename files."  Is that true?
Actions to perform:
Set value
Ok, here's my first problem.  I'm following along with you because I know nothing about Masstagger, so I want to do it step by step.  You said (I think) that we were going to rename files, so I've selected some files in the playlist, right-clicked on the selection and chosen Masstagger->Rename Files.  Now I want to set a value.  The trouble is, I don't see any buttons or menu choices that say "Set value," nor do I see anything labeled "input window."  I see "Output filename format," "Files to process," and "Preview" windows.  I see "update," "Run," and "Cancel" buttons.  I see an empty dropdown list.  Basically, you've lost me.
The rest of the items in that section ("Add Value," et al) are the same way.
Thinking that maybe you meant to rename files, but then changed your mind, I canceled out and selected "Edit tags" from the Masstagger menu.  Nope, no "Set value" choice there either.  Also no "input window," although the "Actions to perform" window looks like a possibility.
You may think at this point that I'm just busting your chops.  I'm not.  I'd truly like to learn how Masstagger works.  I have a bachelor's degree in computer science and a masters degree in software engineering.  I write software all day every day.  I'm pretty good at figuring things out by myself, but I can't even get started with Masstagger.
How about a little section at the beginning of your tutorial that explains, in a step-by-step manner how to do a couple of simple tasks to get the newbies started?
Here's the level of detail I'm suggesting:
  • Enable multimedia keyboard support in fb2k
    • Open fb2k preferences
    • Open the Core property page
    • In the Other section ensure Enable default multimedia keyboard support is selected
  • Assign global keyboard shortcuts
    • Open the Keyboard Shortcuts page
    • Scroll the top Assigned shortcuts window down until you locate a group of shortcuts with (MM) after them
    • Highlight each one that you'd like to use and click on remove
    • Now, in the Action window, highlight the first command you'd like to assign to your multimedia keys
    • Check the Global hotkey box
    • Click in the Key box so that you see a blinking cursor
    • Press the multimedia key you'd like to assign to the action
    • Press the Add key
    • Highlight the next action and repeat this sequence of steps until you have assigned all the keys you want to work in fb2k
    • Close the fb2k preferences window
  • Try out your keys
If you do that for one or two examples, then even newbies like me will be able to follow the rest of your tips.
-- Rick
------- Rick -------
FB2K's Masstagger
  Thanks, I had thought that was referring to the web page being wide.  Guess I missed the part about rejoining them.
FB2K's Masstagger
Actually, it still is unnaturally wide in firefox 0.9+ on 1024x768... Not the strings' fault, though, it seems more like linebreak has been turned off for the whole post and breaks were inserted manually.
Something less offtopic: I noticed that in the latest special installer from case's site the renamer function got updated. Will you include a few words about the new version in the faq? It's really not hard to figure out (took me like 10 seconds), but it could be still worth to mention that creating strings is done in a slightly different way with the latest version.
FB2K's Masstagger
I saw that the formatting of the entire post got messed up somehow. In fact I don't even remember all the lines beeing double spaced. Weird.
I will get back to fixing this and adding a few things in about a day or two as I am low on time right now.
FB2K's Masstagger
I don't suppose there's some way to tweak the auto track number feature so that it will create numbers in the format of 01, 02, 03... instead of 1, 2, 3...  Or is there?  If you could help me out with this, it'd be greatly appreciated, as the current auto track scheme would completely screw the way I've been organizing my mp3s for a while now (it's a little more work, but I like it that way).  I suppose if there isn't a way, I could continue doing it manually, but it's not all that much fun.  Thanks.
FB2K's Masstagger
@studentism: One way to do it:
Make a new masstagger "script" with the following two actions:
1) Auto track number
2) Format value from other fields..
Destination field name = TRACKNUMBER
Formatting pattern = $num(%tracknumber%,2)
Then save it as e.g. "Auto track number XX" or something.
To use it, just pick it from the drop down list in the scrips section, and press Load or Add. Then Run as usual
FB2K's Masstagger
Works like a charm; thank you very much for your assistance.
FB2K's Masstagger
the line width and extra blank lines was making it hard for me to read the guide, so I copied the original post and removed the extra newlines, and cut all the code lines at reasonable positions, and it's now much more browser friendly.
Picmixer, if you want you can copy the reformatted post (from quoting my post) and replace your original post with it. (then I'd remove it here, to make the thread cleaner)
EDIT by picmixer : Many thanks. I removed your edited version from here now and replaced the original with it.  Thanks once more for editing that for me.
FB2K's Masstagger
Wow, I am impressed. Thanks a lot, this is really appreciated.
Admittedly I was busy with a few other things lately and had forgotten (or rather procrastinated) updating this again
Thanks for the effort. I'll change this immediately.
FB2K's Masstagger
it's reallly nothing, I just copied the source of your post to a text editor, reformatted all the paragraphs with extra spaces, and inserted newlines in the lines of code that were too long.
Btw, it might be worth mentionning this fact in the tutorial, so that newcomers know the code lines are meant to be used in one line.  (though, I think the newlines in TAGZ code has no effect, e.g. in the title format window)
Oh, and in fact I inserted newlines inside parenthesis in one case, I missed the 'reasonable position' at least once !
FB2K's Masstagger
right now i'm using this out filename format in masstagger:
%artist% - %album% %date%/$num(%tracknumber%,2) - %title%
i was wondering how i go about adding bitrate info to the end of this line.
thanks.
FB2K's Masstagger
[a href="index.php?act=findpost&pid=226573"][{POST_SNAPBACK}][/a]
Should be easy. Try this:
%artist% - %album% %date%/$num(%tracknumber%,2) - %title% - %__bitrate%
