CUETools.Flake 2.2.2 MD5 mismatch in encoded flac CD image
2022-09-22 17:05:20
reference: https://hydrogenaud.io/index.php?msg=1016166 @Porcus did you test the files? foo_verifier, foo_bitcompare and flac.exe -t showed anomalies. Use -V so that the encoder throws errors when MD5 mismatch. So far only this CD has problem, either in separate files or in one image. Removing --vbr the files encoded properly.5 out of 29 files converted with major problems. Source: "F:\My Music\Game Music\Einhander CD\11 - 突破[Breakthrough].flac" An error occurred while writing to file (The encoder has terminated prematurely with code 5 (0x00000005); please re-check parameters) : "H:\11. 突破[Breakthrough].flac" Additional information: Encoder stream format: 44100Hz / 2ch / 16bps Command line: "F:\Software\Player & Codec\CUETools\CUETools.Flake.exe" -q --ignore-chunk-sizes -8 -V --vbr 4 - -o "temp-4071E17331D7A04CACDD90B682F08D96.flac" Working folder: H:\ Conversion failed: The encoder has terminated prematurely with code 5 (0x00000005); please re-check parameters Source: "F:\My Music\Game Music\Einhander CD\13 - 払暁[Dawn].flac" An error occurred while writing to file (The encoder has terminated prematurely with code 5 (0x00000005); please re-check parameters) : "H:\13. 払暁[Dawn].flac" Additional information: Encoder stream format: 44100Hz / 2ch / 16bps Command line: "F:\Software\Player & Codec\CUETools\CUETools.Flake.exe" -q --ignore-chunk-sizes -8 -V --vbr 4 - -o "temp-322EDDD47174604E85390D5779FAD085.flac" Working folder: H:\ Conversion failed: The encoder has terminated prematurely with code 5 (0x00000005); please re-check parameters Source: "F:\My Music\Game Music\Einhander CD\16 - 焦燥[Impatience].flac" An error occurred while writing to file (The encoder has terminated prematurely with code 5 (0x00000005); please re-check parameters) : "H:\16. 焦燥[Impatience].flac" Additional information: Encoder stream format: 44100Hz / 2ch / 16bps Command line: "F:\Software\Player & Codec\CUETools\CUETools.Flake.exe" -q --ignore-chunk-sizes -8 -V --vbr 4 - -o "temp-F7CE828604ACCD4696C7DC7910958EC2.flac" Working folder: H:\ Conversion failed: The encoder has terminated prematurely with code 5 (0x00000005); please re-check parameters Source: "F:\My Music\Game Music\Einhander CD\17 - 熱圏[Thermosphere].flac" An error occurred while writing to file (The encoder has terminated prematurely with code 5 (0x00000005); please re-check parameters) : "H:\17. 熱圏[Thermosphere].flac" Additional information: Encoder stream format: 44100Hz / 2ch / 16bps Command line: "F:\Software\Player & Codec\CUETools\CUETools.Flake.exe" -q --ignore-chunk-sizes -8 -V --vbr 4 - -o "temp-F171283C44598C4BA3A0616461640EF7.flac" Working folder: H:\ Conversion failed: The encoder has terminated prematurely with code 5 (0x00000005); please re-check parameters Source: "F:\My Music\Game Music\Einhander CD\21 - 無重量[Zero Gravity].flac" An error occurred while writing to file (The encoder has terminated prematurely with code 5 (0x00000005); please re-check parameters) : "H:\21. 無重量[Zero Gravity].flac" Additional information: Encoder stream format: 44100Hz / 2ch / 16bps Command line: "F:\Software\Player & Codec\CUETools\CUETools.Flake.exe" -q --ignore-chunk-sizes -8 -V --vbr 4 - -o "temp-CDA2793624EC41419FFF9CBE5BC0AE02.flac" Working folder: H:\ Conversion failed: The encoder has terminated prematurely with code 5 (0x00000005); please re-check parameters MOD edit: added reference post
