Topic: OptimFROG encoded files and foobar2000 (Read 1101 times) previous topic - next topic
Is there a way to get OptimFROG encoded files (*.ofr) to play in foobar2000 v2 x64?
Out of the box so is it not possible and i haven't found a component for it neither.
Re: OptimFROG encoded files and foobar2000
Should have said that it was for v2 x64..... that component doesn't work
There is no OptimFrog decoder in ffmpeg.
Did you try the component from the homepage? http://losslessaudio.org/Downloads.php at the bottom
Looks like the source code is there so porting to 64bit could be possible?? I'm not even trying though. I'm certain input components are beyond me.
Just emailed Florin and asked him to update his official component to support v2 x64
So I changed my mind and had a go. I have the sample file from here playing in 64bit fb2k...
http://samples.mplayerhq.hu/A-codecs/lossless/
I ran in to one sticking point. New input components are supposed to implement a remove_tags function but I have no idea what to do with it so it does nothing.
edit: a screenshot of my changes, I'm not uploading to github...
https://i.imgur.com/8iGdpwo.png
TEST WITH EXTREME CAUTION (64bit only)
It plays luckynight.ofr, clean portable Foobar 2.0 x64 beta 9, even shows OptimFROG under playlist "Codec" header.
@marc2k3 - Thanks a lot for the updated component. It works fine. Have tested with  5+ OFR encoded files.
I have an updated version.
This correctly displays OptimFROG Decoder under Preferences>Playback>Decoding. Previously, it just displayed OptimFROG
Remove tags has been implemented. It seems writing an empty file_info object does the job.
@mark2k3 -  Thanks for the updated version. :)
ARGH. Another update, hopefully the last.
Includes x86 and x64 dlls with embedded art reading/writing. fb2k v2 only.
I've stuck the source on github.
https://github.com/marc2k3/foo_input_ofr
There are no downloads - the attachment 2 posts above is still the latest.
@mark2k3
Maybe you should make it available on your github foobar2k components page also
It's hardly worth it. This component doesn't need a page to describe how to use it.
Anyway, I've posted an updated release here....
https://github.com/marc2k3/foo_input_ofr/releases
I just tidied up some dead code. No real changes.
@mark2k3
Thnx for making it available on your Github. A description is not needed as u say.
