Topic: How do I suggest new Field standards? (Read 2307 times) previous topic - next topic
If HydrogenAudio includes it in https://wiki.hydrogenaud.io/index.php?title=Tag_Mapping. As "suggested Fields" maybe it will catch on.
Some I want to suggest are -
SONGTYPE - Instrumental; Acapella; Instruments&Vocals
MASTERER
RECORDING_ENGINEER
VOCAL_ENGINEER
I will add more if anyone likes it.
ojos-azules-cat
Re: How do I suggest new Field standards?
I don't see the need for any of those, but "MASTERER" should be "MASTERING_ENGINEER"
I'd say just use the ENGINEER fields if you really want to add these tags. We don't have a GUITARIST, DRUMMER, FLUTIST or CONTRABASSOONIST tags either.
Tag information can be separated using the ; symbol.
So, you can add multiple engineer names to the ENGINEER tag and have them separated using the semi-colon.
You can then add more detailed info into the COMMENT and/or UNSYNCEDLYRICS tag like I do (I also do the latter as some media players like iTunes will display it when playing rather than the COMMENT tag).
That is how foobar2000 presents it to you in order for the user not to have to deal with how different tag formats have different solutions to multi-value fields.
Vorbis comments and APEv2 differ (multiple fields with same key like ARTIST = artistnumberone and ARTIST = artistnumbertwo, vs one field with a list). And infamously, ID3 was created by someone who hasn't heard about a major Aussie rock act, and chose to use "/" as tag separator up to v2.3.
I can literally do this
but i would never get the idea that someone should use it as standard.
And so, with digital, computer was put into place, and all the IT that came with it.
yes, I should've clarified that I was referring to my usage of foobar. In mp3tag it's displayed as a / even if it's entered in foobar as ;
Hopefully op can make use of the very workable suggestions.
