Topic: Forum font too small on full-HD displays (Read 3540 times) previous topic - next topic
Re: Forum font too small on full-HD displays
Reply #50
Yes, RGB letters are not aligned and the font is not smoothed by ClearType. Could be some sort of raster font internal to the program that modern Windows can't take control over it. It is the worst part and therefore I specifically mentioned about it.
Reply #51
If I have some size-inflating hack deep within my OS, feel free to let me know. Here I captured a full-screen dump (still on 24"). To the left, this thread, a screenshot that gets some quoted text. To the right, WavPack.com in default zoom and in double Ctrl minus (two different Chromium browsers).
Reply #52
To me, The top wavpack by far the best, then HA and smaller wavpack last.
Everything is a bit small for my taste in the screenshot except WV new look, although I can't
tell for sure as imgur adds a smudging effect.
wavpack -b3.63hhcs.5
Reply #53
Monitor resolution, display driver resolution scaling, DPI scaling, accessibility settings, browser font settings (something that @shadowking might want to look into!), and browser zoom seem to be all the possibilities on Windows that affect text size on websites.
To me, HA even on 24" 2560x1440 monitor with everything 100% looks OK from a meter away, although WavPack website before increasing font size did not.
Reply #54
I've tried many combos of fonts, css extensions etc..
Firefox is the closest to most consistent look with some breakage:
Set main font=Segoe UI size 16 or 17 and minimum 15
then disable 'allow websites...'
Reply #55
Did you try changing only the font size from default Medium to Large or Very Large?
Reply #56
That appears only in chromium browsers.   I tried chromium and the large setting is very good for me. It appears that its
just an alias for custom zoom value ?
Reply #57
I see its a preset for size 20 font in chromium.
Reply #58
OK. It appears that in FF size 20 = chrome 'large' .  I'll have to experiment to see what breaks or not.
Reply #59
Not sure if it helps with anything, but here are "The" from your screenshot: normal message, quote, top wavpack, bottom wavpack
X
Reply #60
As for the font size on HA, to me it is rather on the smaller side. And because I don't like overcomplicated things, I override this:
font: 87.5%/150% "Segoe UI",-apple-system,BlinkMacSystemFont,"Roboto","Oxygen","Ubuntu","Cantarell","Droid Sans","Helvetica Neue","Trebuchet MS",Arial,sans-serif
with this:
font: 100%/150% sans-serif !important;
The result on 24" 1920x1200, before:
X
and after:
X
Reply #61
It's worth noting that newer fonts like Segoe UI require ClearType/antialiasing/blurry mode to be enabled. I find Windows to be much more visually pleasing with ClearType disabled, and then banishing the disgusting Segoe UI font family. Forcing everything to use older fonts like Tahoma, Times New Roman, and Courier New that were created before the "blurry fonts are awesome" craze makes things look much more crisp and easy to read to me, but YMMV.
Reply #62
To further complicating things, being an Asian, I also visit websites and have files contain Chinese and Japanese. Chinese glyphs can be traditional (e.g. Hong Kong, Macau, Taiwan) or simplified (Mainland China), Japanese can be in Kanji and Kana. In terms of visual complexity, from highest to lowest should be Traditional Chinese > Kanji / Simplified Chinese > Kana.
In the screenshot below, everything in foobar's playlist is Traditional Chinese, two folders in explorer contain Kana and Kanji, compared to the forum fonts.
X
Because it is only possible to choose one font and one size for each item (e.g. folder name), I can't control how the Asian glyphs look like if I use typical Western fonts like Arial, Tahoma, Verdana and such. The font I used in desktop icon, foobar and explorer is Meiryo UI. On the other hand I don't use any plugin and customized font in Firefox.
For ClearType, I also used Windows' built-in ClearType Tuner tool to find the best looking setting for my eye and monitor.
Reply #63
I used to disable cleartype and all blurring possible until 3 years ago.
. With newer displays, better PPI/DPI &
cleartype tuner it can be pretty good.  Not all fonts render
 good just like some of the non-blurred fonts weren't that great either.
The bigger font size is better as it overcomes PPI limitations. If you have
reasonable DPI screen (100 or more), the smaller font won't look smudged .  If you have average display
, the smaller may look blurred, also the Non MS 'web fonts' won't look as sharp.  I wasn't satisfied using 24", but on 22" and now 21 work better.  The new lenovo 21" is best by far.
Reply #64
With ClearType disabled, it's critical to set your browser to forbid websites from using their own fonts; otherwise, sites that use abominations like Segoe UI will be a jaggy, unreadable mess. Modern fonts seem to be designed with font blurring in mind, so when you turn it off, the fonts completely fall apart.
