Topic: AAC Bluetooth codec on Android (Read 4292 times) previous topic - next topic
I have a pair of wireless headphones that only support SBC and AAC, and an Android phone. According to this article, it seems AAC is not a good option if you're using Android?
https://www.soundguys.com/dont-use-airpods-android-20767/
For optimal performance and sound quality, should I use SBC instead? Has anyone compared the two codecs?
Re: AAC Bluetooth codec on Android
Adding clarification.
This topic is asking about changing
Android Settings > System > Developer options > Bluetooth Audio Codec
Have you compared the two codecs?
korth
What phone are you using?  Does it support the AAC codec over Bluetooth? https://bluetoothcheck.com/
What is the audio source?  Flac?  MP3?  M4A?  YouTube? (uses AAC).  SBC seems to be the common codec with all BT devices.    If your phone supports AAC, and the audio is already AAC, then I'd use the AAC codec, as audio quality doesn't seem to noticably degrade with each encoding pass.  However, I believe AAC isn't as easy on battery life.
It is mandatory.
Won't help you.
Regardless of the audio format, it is send to the BT sender as plain PCM.
There it is compressed with the codec negotiated between sender and receiver.
TheWellTemperedComputer.com
Won't help you.
AAC to PCM back to AAC should still be less degraded than going to SBC.  I could tell the difference with AAC files at 96kbps
Honestly, in my experience the difference (if any) between SBC, AAC, and APTX over bluetooth are small enough to not be obvious to me.
There are advantages to SBC and APTX in that they're relatively lightweight to encode and decode.
Wow, I have found an interesting topic here.
The difference between phones is that some use hardware AAC encoder and some use software. If it uses software, it's most likely fdk-aac and you're sure to be safe with a sound quality. If it's hardware... Get ready to have a terrible sound quality that's worse than both SBC and aptX by huge margin. I have experienced that myself.
Opus VBR 256 + SoX
Sometimes the difference could be really dramatic, some unfortunate earbuds (Bose) produce extremely loud clicks where there's nothing like that in the source, only when using AAC - SBC is just fine.
a fan of AutoEq + Meier Crossfeed
My Android phone gave me a terrible experience with AAC, extreme latency (4-5 seconds), and noticeable compression artifacts.  The work around was to disable HD in the Bluetooth settings which is on by default if a newly added device supports it.  SBC was fine on every Android phone I ever had.
Previous Phones: "Kyocera Hydro Icon", "Samsung Galaxy S7" - NO AAC SUPPORT THAT I KNOW OF BOTH HAD BLUETOOTH
Current Phone: "Nokia 8.3 5G" - HAS AAC SUPPORT
Can't confirm latency this huge (more like a second), but compression artifacts is just what I was talking about. Hardware encoders on most (all?) Android phones are complete joke.
so you "downgrade" to SBC. Yeah, you got it right, that's the problem with modern Android phones.
Opus VBR 256 + SoX
