Topic: Problems with Batch converting Cue+wav and Cue +Flac to tracks (Read 1357 times) previous topic - next topic
Hi all!
Cue tools noob here.  I have a database of around 1500 cue sheets + wav or flac. These are all in one folder (yeah I know...).
First questions: Ripping was done with EAC. Should I go for individual conversion to tracks or use batch? Or batch conversion and then reconvert the ones with bad tags?
Second question: I keep getting 'Exception, Flac.exe The system cannot find the file.' when trying single conversion. IS this a templationg error or do I really miss an exe somewhere? When doing batch the program created all the correct folders but only created empty cue's.
I have been looking at the settings, but it is not very beginner friendly sadly...
Edot: Lol, I have been lurking for 13 years ;)
Re: Problems with Batch converting Cue+wav and Cue +Flac to tracks
Just to show some extra info
External encoder executable (.exe) files aren't included. You will need to download.
Or use one of the internal flac encoders.
http://cue.tools/wiki/CUETools_Advanced_Settings:_Encoders
The following page hasn't been updated. libFLAC currently at 1.3.4 and will update to 1.4.1 in CUETools 2.2.3.
http://cue.tools/wiki/CUETools_FLAC_encoders_comparison
korth
Thanks guys!
As my file system and tags are not on point right now, I'll probably go the manual route.
I have a almost similar situation with the output from ripping with EAC - a cue file, a single big wav file and often a folder.jpg. Each is in its folder however. I'm able to use cuetools to batch encode to flac or mp3 etc  - each into a seperate folder based on artist and album etc. I think you will run into challenges with all the files in one folder such as the artwork (if you have any).  I think your best first move is to move the files for each CD into its own folder.
I assume that the name of the artist and album are part of the file name - you'll need to use a Tool like tag&rename or Picard to help with this, or if you are a coder, probably a bit of python will do it. Once you have each CD in its folder, then cuetools will help do a batch encode.
